Hi everyone, this is my first post so I'll try to be as clear as possible.
I am working for a casting company and we are doing auditions to find talents.
I will be filming these auditions on my Canon GL2 and I will record simultaneously the footage on my laptop (with a 500GB hard drive) with Adobe Premiere Pro 2.
The question is : how do I create a pattern (not necessarily on Premiere, could be any program) to quickly edit my footage.
Basically I want to do this :
Can that be done easily? I've tried once the hard way : I took a screencap of each of the chapters, pasted it on a JPEG, then created a menu in Adobe, then made shortcuts on that JPEG to redirect to the chapters.. etc.
What program should I use, how should I do this? Thanks ALOT in advance!!
Pbear.
Edit : Forgot to add that I really need a template because I will re-use this pattern from time to time during other auditions.
Results 1 to 1 of 1
Looking for versatile, easy-to-learn program for authoring Blu-rays
By jeanpave in forum Authoring (Blu-ray)Replies: 19Last Post: 20th Dec 2011, 01:06 -
Creating a DVD menu pattern for repeated use
By pbear23 in forum Authoring (DVD)Replies: 1Last Post: 5th Mar 2009, 03:34 -
Existing Mpeg2... easy authoring to DVD with Subtitles
By durexlw in forum Authoring (DVD)Replies: 3Last Post: 23rd Sep 2008, 16:47 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 19:42
