How do you fix this problem? Error message says I have wrong filters installed but it doesn't tell me which are the right ones? I installed DirectShow Filter Manager and now I'm really confused there are a ton, I'm afraid of breaking something else. Without this I can't create complex menus which is why I made the donation inthe first place. The tutorial movies are really cool. The only thing I would ask for is beaing able to create a scene selection menu as a second menu.![]()
Thread: DirectShow Filter Problems
When are you getting this error?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
When I click on the asset icon after placing it in the vts panel just like they do in the #3 tutorial movie. It says if I can't play in WMP then I can't see the movie in the titlescreen
panel. which they are right I can't play the avi in WMP but I can play it in Windows Media Classic , Ive never had much luck with WMP and if I do get something to play the sound and the video don't seem to align. If I could get that fixed svcd2dvd will probably work also.
Seem to be between a rock and a hard place?
Do you have MPC?
Dwight
- Herm Albright
Yes I meant MPC although when I play the movie the sound is slightly ahead of the video
Media Player Classic right?
I just googled DIrectShow filters for WMP, should I try to download and install if I find the right thing?
For directshow filters i would just install ffdshow (from the tools section of this site). Install those and report back.
I got it fixed. Here is what I did in case anyone else has the problem.
I downloaded the K-lite codec package. The thing that was good about this was it checked all the codecs I had already and if there was a conflict it asked if you wanted to uninstall the one I had. Then it check the registry for any broken codecs, of which I had a bunch, but when it was done all worked well.
Directshow filter for the Animation codec
By roflwaffle in forum Video ConversionReplies: 8Last Post: 12th Oct 2010, 15:09 -
Directshow filter for decoding MPEG-2 TS
By roflwaffle in forum Video ConversionReplies: 5Last Post: 17th Aug 2010, 07:55 -
Directshow Source Filter Issue
By kakskulkarni in forum ProgrammingReplies: 0Last Post: 30th Jun 2010, 18:25 -
DirectShow Sample Grabber filter
By sunnyday28 in forum ProgrammingReplies: 2Last Post: 2nd Dec 2009, 03:26 -
Directshow filter being used...
By fabvideohelp in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2007, 12:27
