I've been using Fairuse Wizard 2.8 to convert my DVD library to MKV (H.264/AC3 5.1).
I have it installed on 3PCs, all on a clean install, all with the same version of everything (ffdshow, X264, etc).
For some strange and odd reason, Fairuse works perfectly on my two desktops (Intel E6850 3.0Ghz & AMD 4400+). However, it does not work on my laptop (Vaio Intel P8400 2.26Ghz). The encoding process (1st & 2nd pass) run perfectly. However, when it gets to the file output process, it hangs 70% of the way on the "The output file is being written..." screen. The "minutes remaining" just continues to grow endlessly until I cancel the process. I've re-imaged the machine again, and I still get same problem.
Any ideas?
Thread: Fairuse Wizard 2.8 Hangs
All computers have same OS?
Is laptop overheating? Check temps, clean your vents
Amount of free disk space on the laptop? Memory configuration / page file configuration?
Other concurrent processes on the laptop? (e.g. antivirus/antispyware) Check task manager
All computers have Vista Ultimate SP1.
Laptop doesn't seem to be overheating. It's only a one month old Sony Vaio VGN-FW139E.
There is at least 40Gig free on both C drive and video partition.
I rebuilt the laptop last night, so it's completely barbone (software wise) without any AV/Firewall or any other processed running in the background.
I'm trying it now with the AVI container instead of MKV to see if that makes a difference. I'll report back.
With AVI, exactly same settings as before (codec, audio), it worked without a problem.
I did just notice that my Haali Media Splitter version is the latest on the laptop, whereas it's an older version on my desktop where it has no problems creating MKV. That couldn't be it, could it?
problem with fairuse Wizard
By minkz in forum Video ConversionReplies: 4Last Post: 4th Oct 2011, 14:06 -
Fairuse Wizard
By Simmons in forum Video ConversionReplies: 1Last Post: 17th Aug 2011, 18:34 -
Fairuse wizard
By pensioner in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2010, 12:37 -
Fairuse Wizard
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2010, 05:38 -
Another program like Fairuse Wizard?
By glideroggan in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2008, 14:25
Statistics
Newest guides
Latest tool updates
New media comments
