Hi all
Can you recommend a GUI for ffmpeg that would fulfill these criteria?
1. I don't have installation rights, so it needs to be a stand-alone app.
2. I want to be able to queue up the jobs and leave the conversion running while I get on with other stuff.
3. I want to convert to a -sameq mpeg, ready for editing in VirtualDub or WMM.
I thought that WinFF was ideal, but I don't think I can select MPG as the output (unless I choose a target format like VCD).
Many thanks in advance.
Thread: Recommend a GUI for FFmpeg
Avanti
if you need help setting up the template let me know"I'll give you five dollars if you let me throw a rock at you"
In WinFF, if you pick DVD format you'll get your mpg,ready for editing in VD, but you do know you'll need the mpeg.vdplugin to import .mpg in VD right? You could also use VirtulaDub MPEG2............
"I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
45tripp
Nice! Thanks so much. Took a while to work out how to make a template so I could use job control, but it's just what I want - thanks.
t0nee1, thanks, but I don't want to change the video dimensions, and I think using the DVD target would do that.
WinFF might be fine. I haven't tried it, since I had begun writing my own GUI before there were any good ones or I just havent found WinFF or AVANTI. So I created SmartFFmpeg which is worth trying as well since it might have features the others don't have. Like Preset-management, individual conversion settings per task/file, output-filename suggestion etc...
http://freeware.satria.de/SmartFFmpeg/
No ads, no money, no registration. Just freeware
The page itself is in german but the tool is English.
Full FFMpeg/Mencoder gui?
By TSJNachos in forum Video ConversionReplies: 9Last Post: 16th Jun 2011, 02:24 -
AutoFF a new gui for FFmpeg (v. 0.99.8)
By buzzqw in forum LinuxReplies: 34Last Post: 16th Aug 2010, 09:49 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 17Last Post: 7th Sep 2009, 13:59 -
Another ffmpeg gui (autoffmpeggui) (update 28/07/2009)
By buzzqw in forum LinuxReplies: 12Last Post: 28th Jul 2009, 03:53 -
New (advanced) FFmpeg GUI for Windows OS builds.
By Chris K in forum Video ConversionReplies: 119Last Post: 24th Nov 2007, 06:15
