    Hi I have a adult dvd which has a pin code on it.
    I can rip the dvd no problem but cant seem to get round the pin section.
    Does anyone know how to make the rip play by removing the pin protection ?
    I have run it through ifo edit and cant seem to make it play the vobs it always goes back to this pin code screen.
    Any help would be good.
    Cheers
    P.
  2. You can try to copy only the movie VOBs and create a new set of IFOs with IFOedit.
    If you are talking about " Parental Management" setting, than PgcEdit will do.
    Load your file, click DVD in upper tool bar/ drop down menu/ Remove Parental Management.
