I have a 2004 Sony 50" Grand Wega 720p/1080i tv. It does not have an HDMI input, and only 1 x DVI.
I would like use my HD satellite receiver and my laptop with this tv. Both the receiver and the laptop have HDMI outputs but no DVI outputs.
I was planning to get this cable:
http://www.ramelectronics.net/produc...emId=224362553
and this switch:
http://www.ramelectronics.net/produc...emId=224362568
to enable me to connect both hdmi outputs to this tv. I believe there should be no issues, however, I just wanted to post before I make the purchase in case someone is aware of any incompatibility issues.
Thanks,
Michael
Results 1 to 12 of 12
Thread: Advice with HDMI to DVI setup
Those should work as long as your TV supports HDCP. Try the cable alone first. $30 is a lot for a 10 foot HDMI/DVI cable. DVI doesn't carry audio so you'll need to run audio separately.
I'm no expert on HDMI or DVI cables as I still use component, but this looks like the same thing, but at 1/3 the cost:
http://www.monoprice.com/products/pr...seq=1&format=2
Thanks guys,
I ended up ordering from monoprice:
2218 HDMI DVI cable CL2 Rated (For In-Wall Installation) (24AWG) w/net jacket- 6ft (Gold Plated)
1 $7.28 $7.28
3047 2X1 Enhanced Powered HDMI Switcher w/ Remote
1 $20.90 $20.90
3661 HDMI 1.3a Category 2 Certified CL2 Rated (In-Wall Installation) Cable (24AWG) w/ Net Jacket - 6ft (Gold Plated Connectors)
1 $9.50 $9.50
3662 HDMI 1.3a Category 2 Certified CL2 Rated (In-Wall Installation) Cable (24AWG) w/ Net Jacket - 10ft (Gold Plated Connectors)
1 $12.64 $12.64
My dvi input is hdcp compliant so it all should work. I will report back when i got it set up,
Thanks again for your help,
Mike
I use their cables for HDMI and they work fine. My longest run is to my projector, about 45ft, and no problems. I also have their 4 input HDMI switcher and now wish I had got a 5 or 6 input switcher.
I need some help.
I have a Boxlight 750M projector, I want to use it as my projector for a home theater. I have an Onkyo HT s6100 receiver, I want to connect my cable box, Xbox to the reciever using HDMI connection and run to the projector which has a DVI (10 x3 pin set up) using the receiver HDMI output. I can not find a DVI (30x3 pin) to HDMI cable. What is my best solution/aternative?
Mark
Try an M1 to HDMI adapter:
http://www.infocus.com/Accessories/C...MI_ADPT_R.aspx
Or try a DVI to DVI M1 adapter along with a HDMI/DVI cable.
thank you for the information.
I looked at the adapter, it looks like it would work. I called Infocus to discuss , they mentioned that beacuse my receiver is brand new, the encryption may or may not work with the projector.
Does this sound reasonable, is there encryption with HDMI?
thanks in advance
HDMI devices use a 'handshake' between the devices to see that they are HDCP compliant. It usually works, but you never know till you try it. From Wikipedia: http://en.wikipedia.org/wiki/High-ba...ent_Protection
HDCP isn't required by HDMI or DVI. But most A/V sources will require HDCP. Your laptop should be able to connect without HDCP but you won't be able to play blu-ray discs (the player software will require HDCP). Your satellite receiver probably won't connect without HDCP.
How about Xbox 360 and FIOS set top boxes. I am using my Xbox as DVD as well?
thank you in advance
FIOS and cable boxes will almost certainly require HDCP. Most upscaling DVD players also. Hollywood has worked very hard to lock up all those devices. I don't now about the game consoles.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / HDTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
Splitting DVI and HDMI signals. Veterans please check my setup
By anubis13 in forum ComputerReplies: 9Last Post: 21st Jan 2010, 16:14 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Aug 2009, 23:14 -
Will a DVI-D to HDMI cable work for this setup?
By anthojoe in forum DVB / HDTVReplies: 1Last Post: 27th Nov 2007, 12:59
