Hi
I have a couple of mpeg 4 file + h264 that wont play on my divx player. Obviously doesn't support mpeg 4. it will play avi/divx though.
I want to convert them to play as they are on my dvd player without converting them into a DVD (vobs) which i have already tried and work but are too large as only one file per dvd disc. i want to put all of them onto one disc.
Does anyone know which converter is best without loss of quality. i have searched for tools but they all seem to be converting the other way i.e. dvd to mp4.
Any help appreciated thanks.![]()
Thread: which converter for mpeg-4 h264
As a general rule, DVD players that claim to support mpeg-4 only support mpeg-4 part 2 (Divx/Xvid being the most common versions), and only within a narrow set of encoding parameters.
For H264 source, I would suggest Xvid4PSP, using the AVI (Hardware) Format, and Xvid HQ Ultra for Video Encoding. You won't have any control over the file size, but you will get the least quality loss.
Personally, if I have a high quality H264 format movie, I find I get better quality converting it to DVD with FAVC than converting it to Divx/Xvid.
If you want to convert to Divx, please see this sticky:
http://forum.videohelp.com/topic357003.html
It lists which options are problematic for DVD players that play Divx. If you use an encoder like Dr. Divx that has a Home Theatre setting, use that.
What best converter to convert MPG to FLV/H264?
By Leo99 in forum Video ConversionReplies: 6Last Post: 21st Apr 2012, 10:16 -
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Which Converter For MKV H264/ CQ/ CUDA Processing
By shagratt71 in forum Video ConversionReplies: 1Last Post: 8th Oct 2011, 13:41 -
H264 MP4 causing DIVX Converter to Crash
By dudeman316 in forum Video ConversionReplies: 7Last Post: 5th Mar 2009, 08:13 -
MPG to h264 w/ATi TransCode Converter 1.01b, audio just won't encode *argh*
By ultradouche in forum Newbie / General discussionsReplies: 2Last Post: 26th Nov 2007, 09:33
Statistics
Newest guides
Latest tool updates
New media comments
