Could i have a faulty hard-drive because i have problems when i transfer my dv video to my pc,I get alot of dropped frames and i mean alot and the only way i can stop having dropped frames is to turn off write caching on the disk
Or is there something that could cause this to happen??
Specs:
XP Pro
Corsair VX 450W ATX PSU
Asus A8N-SLI Premium
AMD Athlon 64 3700 processor
Western Digital Caviar WD2500JB
BFG GeForce 8800 GTS 320MB
GeIL 2GB
Results 1 to 30 of 34
Western Digital Data Lifeguard Diagnostics
http://www.softpedia.com/get/System/Hard-Disk-Utils/Western-Digital-Data-Lifeguard-Diagnostics.shtml -
Thanks for that,Sorry i forgot to say ive used that program and there is no problems,Thats whats odd i know it doesn't come up with anything but wouldn't the write caching point towards a hard-drive problem
is the HD device property is set UDMA 5 ?
just trying to help.
it could be the software you are using to transfer the video to your PC,or usb,firewire issue,,,, -
Hi
Yep its in DMA mode
Im using firewire and ive tried two different external firewire cards.
Software,WinDv and windows movie maker same issue.
Ive done a defrag only have programs that need to be running
Ive done all the checks thats why im a bit lost
I guess u need to wait for Level 2,or 3 tech support. lol. please wait a moment
Is this a new problem ie have you successfully captured before ?
If this is the first time you are capturing, the problem may simply be that you only have one hard drive. You may think you are not running any other programs while you capture but you are - it's called Windows and that it's self is constantly reading and writing from the drive. At the same time you are trying to write data very quickly to the same drive. Windows will have a problem.
Solution. A separate hard drive just for capturing/editing.
Just my 2 cents. -
IMO you've already solved your problem. Turn off write caching when you capsfer. This problem is described here (click here). And while most of the information is aimed at W2K, it states that the problem also effects XP, and according to M$, they don't have a fix for it in XP.
Buy My Books -
No ive done a bit of caputure before and it had allways dropped frames,I know you are right i should have a seperate hard-drive but i dont capture alot just at birthdays xmas etc..Also i didn't want to get another hard-drive and find i still had the same problemOriginally Posted by DB83
Yea i found a way to solve my problem,But really i dont think i should have to do this im sure there is something wrong somewhere,Thanks for the link nice bit of reading but i just cant belive its a problem with xp so far ive not spoke to anyone who has the same problem as meOriginally Posted by gadgetguy -
It's a problem with certain configurations of certain hardware running WinXP. Replacing or putting in a different hard drive would likely solve the problem, or using a different motherboard, or a number of different possibilities. It's precisely because it doesn't affect the majority of people that M$ isn't going to do anything about it.
Buy My Books -
ORight i see now thanks
So if i do get another hard drive what should i get same make? The thing is if i do go for a Western Digital then it might happen again.. -
does't have any thing to do with HD jumpers slave/master?
Sorry going to sound thick what do you mean when you say it doesn't have any thing to do with HD jumpers?,My HD is master.Originally Posted by MJA
I have no idea what make the card is it came with the moboOriginally Posted by minidv2dvd
It came with two external and one onboard firewire
EDIT: Hold on when i mean external i mean its a pci firewire card -
ok, it's a normal internal firewire card with rear panel ports. just making sure it wasn't one of those firewire to usb converters.
WinDV wouldn't have worked with that.Originally Posted by minidv2dvd
Try moving your firewire card to a different slot. That might be enough of a change to affect the problem. If you want to add a drive, I would try a Seagate, but only because your current drive is WD, (if your current drive was a Seagate, I'd be advising trying a WD)."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
No ive done a bit of caputure before and it had allways dropped frames,I know you are right i should have a seperate hard-drive but i dont capture alot just at birthdays xmas etc..Also i didn't want to get another hard-drive and find i still had the same problemOriginally Posted by jezzer
__________________________________________________ ____________________________________________
Unless you're willing to live with having to turn off caching, DB83 gave you the only solution. I was doing miniDV capture to un-compressed AVI without dropping a single frame (25 meg/sec sustained) and that was with just an AthlonXP 2000 on Win2k and two 60 GB Seagates. You don't need to get a large drive 160 GB drives are selling for around $50 and you can get 80 GB's for less than $40.
Even if you don't think you'll use it that much, you just might be surprised how handy it will come in. If you do any file processing (think shrinking, compressing, blanking...) going from one drive to the other will speed up the work considerably. You could also use it to back up your data and save images of your main drive with Acronis True Image (it'll save your ass when disaster strikes). -
Ok i will try putting it in another slotOriginally Posted by gadgetguy
I think even if it does work which i hope,I will still get aanother HD
nic2k4 has made a good point aswell a second HD would be good to back stuff up aswell
Thank you all
I don't think I said anything that insinuated that you shouldn't get one, but if you or anyone else interpreted it that way then let me clear it up now. I highly recommend using a separate hard drive for capsfer/editing/encoding video, whether you have problems capsferring to your main drive or not.
Buy My Books -
Nope you didn't say i shouldn't get one your post was helpful
Ive just had a thought:
With a internal HD it will be powered up and would have the same risks as the source drive if something went wrong,So wouldn't it be better to get a external HD so then its not powered from the pc? -
For backups, an external drive make sense, but you should really use an internal drive for capsferring. Theoretically it should work, but many people experience dropped frames, which of course is how this whole thing started.
Buy My Books -
Ok ill start off with a internal drive,I dont want to be back here saying ive got dropped frames with a external drive lol
Cheers -
An external esata drive will be as fast as an internal drive.
And an USB drive should be fast enough to keep up. None the less, people experience problems capsferring to an external drive, it's not always about speed.
Buy My Books -
An eSATA connection is the same as an internal SATA drive -- just the cabling and connectors are different. USB is a protocol developed for low bandwidth applications. Adding hard drives to it is a kludge with small transfer packets and high latency.
And if the external power supply has a problem so does the eSATA drive, but that's all beside the point. Nowhere did I say an external drive wouldn't work, only that some people have experienced problems and because this started with capsfer problems, it makes more sense to stick with what fewer people have complained about.
Buy My Books -
Just a small update:
Instead of using the onboard connection i tried the other card that came with the mobo its not a pci card,the firewire card has a cable comming out of the card with a little plug that goes into the motherboard.Well i tried that still the same,Im still going to buy a second HD as advised but is it going to be any better if i buy a pci firewire card,Is it going to be any better than the onboard
Cheers again
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 17:18 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
