Hello
I have Linux Mint 4.0 Daryna and I am using the Sun Xvm Virtualbox 1.60 (not the OSE version). I have a WinXP VD that I am using and it works great.
I recently noticed that Virtualbox was up to 2.0.2 so I want to upgrade. Will my WinXP VD still work? Also I assume I want to download the Ubuntu 7.10 Gutsy Gibbon version (since that is what Mint is based on).
Just wanted to be safe before doing anything LOL
- John "FulciLives" Coleman
P.S.
Here is the link: http://www.sun.com/software/products/virtualbox/
When I updated Virtualbox, the application offered to automatically update the virtual machine for me.
(And just in case you weren't aware of this function...)
You may want to do a "VBoxManage clonevdi <input.vdi> <newcopy.vdi>" to create a backup of your virtual machine - just in case you need to go back !
Good luck....
I did the update and it went fine ... I didn't have to update the VDI file just the "Guest Additions" ... so all in all it went smoothly.
Now that I remember or think about it I did have to update the VDI the last time I upgraded (which was from the OSE 1.5x version to the Sun non-OSE 1.6x version) but this time it didn't ask to do that so I guess it didn't need to be done.
VirtualBox is the best thing since sliced bread
I think the physical VDI file format changed between 1.5 --> 1.6 (for one thing it now contains a signature saying "Sun xVM xxxx"Originally Posted by FulciLives
- hence the need to update the VDI format at that time. AFAIK there was no VDI format change in VBox V2, and no major (virtual) hardware changes, so as you discovered the update should have gone quite smoothly.
I agree that VBox is great. I just wish it made cloning easier, and made better provision for mobile apps. Oh - and it needs much simpler networking support. The core functionality is excellent though.
Upgrading my htpc, need advice
By einsi in forum Media Center PC / MediaCentersReplies: 9Last Post: 13th Nov 2009, 15:35 -
VirtualBox & USB problem
By kenmo in forum ComputerReplies: 12Last Post: 3rd Nov 2009, 18:45 -
Need Advice on Upgrading CPU
By AuroEdge in forum ComputerReplies: 19Last Post: 26th Oct 2009, 01:22 -
virtualbox 1.62 HIN shared folders with Linux Mint 5.0 hosting Xpro
By Verlager in forum LinuxReplies: 1Last Post: 7th Jul 2008, 10:47 -
Virtualbox - how do I add cd drive and graphics drivers?
By yoda313 in forum ComputerReplies: 3Last Post: 8th Mar 2008, 21:05
Statistics
Newest guides
Latest tool updates
New media comments
