Hi all, im really struggling with this:::::
Basically I have a 15 minute basketball game edited on premiere pro cs3, recorded with a Dv camcorder,
I understand that i can upload 500mb of film to vimeo for web veiwing,
now ive looked through tutorials and searched google but im still scrathcing my head, can someone give me a quick
tutorial on how to export this movie(Premeire cs3) as a 500mb file for uploading to vimeo..
Am i right in thinking thats how you do it,, Export edited timelime using media encoder until you get the outputed
file to as close to 500 mb as poss..
original footage was a pal widescreen camcorder
regards
Thread: vimeo uploading help
Deinterlace the footage. Resize to 1024x576 and save as Xvid 3500kbs or higher
cheers i found this on line somewhere
http://eugenia.gnomefiles.org/images/pcs3-h264.jpg
my question is, I can set the target bitrate to what i want, so do i set it until the outputed file size will be 500 mb?
or doest it matter what size file you upload to vimeo as it does its own converting???????
file size is equal to total bitrate(audio plus video) times the running time of the video in seconds. from that you should be able to determine something close to 500mb to set your encoder to. if you try to upload something bigger than 500mb, they will just reject it at the end and all your uploading time will be wasted.
Question from beginner. Trying to convert .vob to play on Vimeo
By thegreatdanton in forum Newbie / General discussionsReplies: 2Last Post: 11th Mar 2011, 20:26 -
no image from vimeo
By butterflies in forum Video StreamingReplies: 1Last Post: 22nd Dec 2009, 03:12 -
Processing power for H.264... YoutubeHD vs Vimeo vs ???
By The111 in forum Newbie / General discussionsReplies: 39Last Post: 1st Jul 2009, 06:10 -
Problems with Vimeo Encoding
By Xenon77 in forum Video StreamingReplies: 2Last Post: 28th Apr 2009, 12:04 -
Vimeo Conversion
By tmw in forum Video ConversionReplies: 0Last Post: 19th Aug 2008, 10:07
Statistics
Newest guides
Latest tool updates
New media comments
