Hi All
I have downloaded my favourite youtube video songs,But i wants to watch in full screen mode,when i do this the video quality looks very rough not clean and clear.what can be done to see this?
Is it possible to convert this tiny screen in diffrent format,to watch on laptop screen.please help thanks in advance.
Results 1 to 12 of 12
Thread: How to convert youtube videos
What can be done about it ?Originally Posted by jackyshaikh
Very little. You have downloaded a low resolution, heavily compressed, low quality source. You want to make it bigger, but any enlarging will simply make the compression artifacts worse. You might try one of the deblocking filters in virtualdub (the latest version can load flv files with a plugin), but mostly they will just make the clip softer and blurry.
There are plenty of programs that can enlarge and convert your clip - SUPER, Media Converter, Media Coder etc - but none of them can put back quality that has long been squeezed out of it. If you really want quality, find a better source than youtube.
You don't have to convert them to be able to watch them on a laptop or any other kind of computer. You can play them using VLC Player.Originally Posted by jackyshaikh
I also usually use SUPER , i choose to convert to avi container.. and then select "copy stream", and "copy audio".
This usually results in a fine lossless "conversion"
(usually means, flv's can be comrpessed in different codecs, fiddle around with it, aim for lossless conversion)
Thankyou very much guys for all your responses.well i had downloaded super player,but i need more info from all of you buddies.
How do i play/watch those video songs which i have downloaded from youtube in super player?
Do i have to convert these FLV'S files in diffrent format to watch in full screen mode?
If so how to do that,I don't have any knowledge of video conversion.
Or is these youtube videos songs can be burn on DVD'S to watch later on how?
please giude me buddies,any help would be appreciated thanks in advance.
Super is a conversion/encoding program, not a player. I already told you how you can watch downloaded FLV or MP4 videos.
Sorry Manono i really don't know the ABCD about this what you called encoding.My aim is to watch these small screen videos in full screen mode on my laptop,if it is possible.
I have already downloaded super,but i need step by step instruction to convert this songs which are already in my folders as iam watching these in KM player,but when i make this bigger all the songs images looks very rough.
Now i hope you really understood what i need to do.please help thanks in advance.
I'm not sure why you'd expect otherwise. The standard 320x240 FLVs from YouTube are garbage even at 320x240, and look much worse fullscreened. Believe me, they won't look any better, and will probably look worse, after being converted to something else with Super or any other program....when i make this bigger all the songs images looks very rough.
If you're going to download them, at least get the higher quality 480x360 MP4 videos (if one exists). Use KeepVid for downloading the higher quality versions.
http://keepvid.com/
The only way to "improve" those flv videos is through heavy filtering.
You need a commercial program, demon's Video Enhancer 1.9.2. That gonna convert your 320x240 source to something better, like 720X480 which is "ok". At the same time you need to use some filters: MSU smart deblocking and another commercial filter, called: Neat Video. Finally, you sharp a bit your video, with a filter called msu smart sharpen.
This is the best you can do.
@manono thanks for reply.how do i check the size,whether it is standard or higer quality before downlaoding?
@Satstorm From where can i download demon's Video Enhancer 1.9.2. is there any trail version to check the results?
Thankyou very much guys i apprecaite your responses.
The MP4 is the higher quality version, if it exists.
Google "Video Enhancer". It pop ups first in the list. There is a trial version AFAIK.
The same combination (video enhancer + neat video + msu smart deblocking/sharpen) improves and the mp4 youtube files.
My videos are up on youtube, how do they look?
By fuzzblaster in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2010, 19:52 -
Why won't YouTube convert a video that was downloaded from YouTube?
By brassplyer in forum Video StreamingReplies: 0Last Post: 5th Dec 2008, 04:47 -
Upload videos to a site, automatic convert to FLV (just like youtube)
By lordsmurf in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2007, 15:07 -
Youtube videos
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 04:05
