Get the source from here.
http://mo-de.net/opensource/php/buil..._for_avysinth/
Any modifications or improvements please send to me Lex Peters, the author.
Q and A
- What you need to use this script?
You will need the ability to execute php scripts. The environment I use is a L.A.M.P. stack (Linux, Apache, MySQL and PHP). You don’t need the MySQL part.
- Who should use this?
If you have a digital camera that you take lots of videos with sometimes you might want to stitch them together to create one long video. I use a Nikon and a Canon camera with the same memory and they generate different file formats, Motion JPG avi and Quicktime (mov). This script will create the syntax needed by Avysinth to concatenate, put together the videos.
- How to use this script?
Once you have an environment setup, like a LAMP or WAMP stack then place the script where apache serves up pages and execute the script with two parameters.
Example:
On a local area network the Linux web server looks for a mounted shared drive from the Windows computer at thepath=/home/smbshare1/images/2008_May_2/101CANON
It will read the files within this directory/folder and search for any .avi, .AVI, .mov, .MOV etc. files. Don’t get confused with the slashes, Unices use forward slashes and Windows use backwards slashes.
Because the path is on a Windows computer and Avysinth needs the absolute path to the files you need to add this information to the second parameter.
displaypath=C:\images\2008_May_2\101CANON\
This is what a call might look like.
http://192.168.2.299/pathto/script/b...May_2/101CANON
If you plan to combine different types of video formats, that is QuickTime mov and avi, files then add this variable “variableMovieToMatchFPS “ and give it a value in Avysinth to the video you want the other format to convert to. I convert the QuickTime frames per second to the avi movies.
If you only have QuickTime movies then run the code and do a find and replace.Code:variableMovieToMatchFPS=avisource ("C:\images\2008_May_2\101CANON\MVI_0160.AVI", false )
“.ConvertToYV12().ConvertFPS(variableMovieToMatchF PS)” to something else or nothing.
Here is an example output. Image how long it would take to do this manually?
Code:a = QtInput("C:\images\2008_May_2\101CANON\DSCN3227.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) b = QtInput("C:\images\2008_May_2\101CANON\DSCN3228.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) c = QtInput("C:\images\2008_May_2\101CANON\DSCN3229.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) d = QtInput("C:\images\2008_May_2\101CANON\DSCN3230.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) e = QtInput("C:\images\2008_May_2\101CANON\DSCN3231.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) f = QtInput("C:\images\2008_May_2\101CANON\DSCN3232.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) g = QtInput("C:\images\2008_May_2\101CANON\DSCN3233.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) h = QtInput("C:\images\2008_May_2\101CANON\DSCN3234.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) i = QtInput("C:\images\2008_May_2\101CANON\DSCN3235.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) j = QtInput("C:\images\2008_May_2\101CANON\DSCN3236.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) k = QtInput("C:\images\2008_May_2\101CANON\DSCN3237.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) l = QtInput("C:\images\2008_May_2\101CANON\DSCN3238.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) m = QtInput("C:\images\2008_May_2\101CANON\DSCN3239.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) n = QtInput("C:\images\2008_May_2\101CANON\DSCN3240.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) o = QtInput("C:\images\2008_May_2\101CANON\DSCN3241.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) p = QtInput("C:\images\2008_May_2\101CANON\DSCN3242.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) q = QtInput("C:\images\2008_May_2\101CANON\DSCN3243.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) r = QtInput("C:\images\2008_May_2\101CANON\DSCN3244.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) s = QtInput("C:\images\2008_May_2\101CANON\DSCN3245.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) t = QtInput("C:\images\2008_May_2\101CANON\DSCN3246.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) u = QtInput("C:\images\2008_May_2\101CANON\DSCN3247.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) v = QtInput("C:\images\2008_May_2\101CANON\DSCN3248.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) w = QtInput("C:\images\2008_May_2\101CANON\DSCN3249.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) x = QtInput("C:\images\2008_May_2\101CANON\DSCN3250.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) y = QtInput("C:\images\2008_May_2\101CANON\DSCN3251.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) z = QtInput("C:\images\2008_May_2\101CANON\DSCN3252.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) aa = QtInput("C:\images\2008_May_2\101CANON\DSCN3253.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) bb = QtInput("C:\images\2008_May_2\101CANON\DSCN3254.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) cc = QtInput("C:\images\2008_May_2\101CANON\DSCN3255.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) dd = QtInput("C:\images\2008_May_2\101CANON\DSCN3256.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ee = QtInput("C:\images\2008_May_2\101CANON\DSCN3257.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ff = QtInput("C:\images\2008_May_2\101CANON\DSCN3258.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) gg = QtInput("C:\images\2008_May_2\101CANON\DSCN3259.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) hh = QtInput("C:\images\2008_May_2\101CANON\DSCN3260.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ii = QtInput("C:\images\2008_May_2\101CANON\DSCN3261.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) jj = QtInput("C:\images\2008_May_2\101CANON\DSCN3262.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) kk = QtInput("C:\images\2008_May_2\101CANON\DSCN3263.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ll = QtInput("C:\images\2008_May_2\101CANON\DSCN3264.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) mm = QtInput("C:\images\2008_May_2\101CANON\DSCN3265.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) nn = QtInput("C:\images\2008_May_2\101CANON\DSCN3266.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) oo = QtInput("C:\images\2008_May_2\101CANON\DSCN3267.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) pp = QtInput("C:\images\2008_May_2\101CANON\DSCN3268.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) qq = QtInput("C:\images\2008_May_2\101CANON\DSCN3269.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) rr = QtInput("C:\images\2008_May_2\101CANON\DSCN3270.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ss = QtInput("C:\images\2008_May_2\101CANON\DSCN3271.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) tt = QtInput("C:\images\2008_May_2\101CANON\DSCN3272.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) uu = QtInput("C:\images\2008_May_2\101CANON\DSCN3273.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) vv = QtInput("C:\images\2008_May_2\101CANON\DSCN3274.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ww = QtInput("C:\images\2008_May_2\101CANON\DSCN3287.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) xx = QtInput("C:\images\2008_May_2\101CANON\DSCN3316.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) yy = QtInput("C:\images\2008_May_2\101CANON\DSCN3317.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) zz = QtInput("C:\images\2008_May_2\101CANON\DSCN3318.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) aaa = QtInput("C:\images\2008_May_2\101CANON\DSCN3319.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) bbb = QtInput("C:\images\2008_May_2\101CANON\DSCN3320.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ccc = QtInput("C:\images\2008_May_2\101CANON\DSCN3321.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ddd = QtInput("C:\images\2008_May_2\101CANON\DSCN3322.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) eee = QtInput("C:\images\2008_May_2\101CANON\DSCN3323.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) fff = QtInput("C:\images\2008_May_2\101CANON\DSCN3324.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ggg = QtInput("C:\images\2008_May_2\101CANON\DSCN3325.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) hhh = QtInput("C:\images\2008_May_2\101CANON\DSCN3326.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) iii = QtInput("C:\images\2008_May_2\101CANON\DSCN3327.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) jjj = QtInput("C:\images\2008_May_2\101CANON\DSCN3328.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) kkk = QtInput("C:\images\2008_May_2\101CANON\DSCN3329.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) lll = QtInput("C:\images\2008_May_2\101CANON\DSCN3330.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) mmm = QtInput("C:\images\2008_May_2\101CANON\DSCN3331.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) nnn = QtInput("C:\images\2008_May_2\101CANON\DSCN3332.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ooo = QtInput("C:\images\2008_May_2\101CANON\DSCN3333.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) ppp = QtInput("C:\images\2008_May_2\101CANON\DSCN3334.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) qqq = QtInput("C:\images\2008_May_2\101CANON\DSCN3335.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) rrr = QtInput("C:\images\2008_May_2\101CANON\DSCN3336.MOV ", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0).ConvertToYV12().ConvertFPS(variableMovieToMatchFPS) sss = avisource ("C:\images\2008_May_2\101CANON\MVI_0160.AVI", false ) ttt = avisource ("C:\images\2008_May_2\101CANON\MVI_0161.AVI", false ) uuu = avisource ("C:\images\2008_May_2\101CANON\MVI_0162.AVI", false ) vvv = avisource ("C:\images\2008_May_2\101CANON\MVI_0163.AVI", false ) www = avisource ("C:\images\2008_May_2\101CANON\MVI_0164.AVI", false ) xxx = avisource ("C:\images\2008_May_2\101CANON\MVI_0165.AVI", false ) yyy = avisource ("C:\images\2008_May_2\101CANON\MVI_0166.AVI", false ) zzz = avisource ("C:\images\2008_May_2\101CANON\MVI_0167.AVI", false ) aaaa = avisource ("C:\images\2008_May_2\101CANON\MVI_0168.AVI", false ) bbbb = avisource ("C:\images\2008_May_2\101CANON\MVI_0169.AVI", false ) cccc = avisource ("C:\images\2008_May_2\101CANON\MVI_0170.AVI", false ) dddd = avisource ("C:\images\2008_May_2\101CANON\MVI_0171.AVI", false ) eeee = avisource ("C:\images\2008_May_2\101CANON\MVI_0172.AVI", false ) ffff = avisource ("C:\images\2008_May_2\101CANON\MVI_0173.AVI", false ) gggg = avisource ("C:\images\2008_May_2\101CANON\MVI_0174.AVI", false ) hhhh = avisource ("C:\images\2008_May_2\101CANON\MVI_0175.AVI", false ) iiii = avisource ("C:\images\2008_May_2\101CANON\MVI_0176.AVI", false ) jjjj = avisource ("C:\images\2008_May_2\101CANON\MVI_0177.AVI", false ) kkkk = avisource ("C:\images\2008_May_2\101CANON\MVI_0178.AVI", false ) llll = avisource ("C:\images\2008_May_2\101CANON\MVI_0179.AVI", false ) mmmm = avisource ("C:\images\2008_May_2\101CANON\MVI_0180.AVI", false ) nnnn = avisource ("C:\images\2008_May_2\101CANON\MVI_0181.AVI", false ) oooo = avisource ("C:\images\2008_May_2\101CANON\MVI_0182.AVI", false ) pppp = avisource ("C:\images\2008_May_2\101CANON\MVI_0183.AVI", false ) qqqq = avisource ("C:\images\2008_May_2\101CANON\MVI_0184.AVI", false ) rrrr = avisource ("C:\images\2008_May_2\101CANON\MVI_0185.AVI", false ) ssss = avisource ("C:\images\2008_May_2\101CANON\MVI_0186.AVI", false ) tttt = avisource ("C:\images\2008_May_2\101CANON\MVI_0187.AVI", false ) uuuu = avisource ("C:\images\2008_May_2\101CANON\MVI_0188.AVI", false ) vvvv = avisource ("C:\images\2008_May_2\101CANON\MVI_0189.AVI", false ) wwww = avisource ("C:\images\2008_May_2\101CANON\MVI_0190.AVI", false ) xxxx = avisource ("C:\images\2008_May_2\101CANON\MVI_0191.AVI", false ) yyyy = avisource ("C:\images\2008_May_2\101CANON\MVI_0192.AVI", false ) zzzz = avisource ("C:\images\2008_May_2\101CANON\MVI_0193.AVI", false ) aaaaa = avisource ("C:\images\2008_May_2\101CANON\MVI_0194.AVI", false ) bbbbb = avisource ("C:\images\2008_May_2\101CANON\MVI_0195.AVI", false ) ccccc = avisource ("C:\images\2008_May_2\101CANON\MVI_0196.AVI", false ) ddddd = avisource ("C:\images\2008_May_2\101CANON\MVI_0197.AVI", false ) combined = a + b + c + d + e + f + g + h + i + j + k + l + m + n + o + p + q + r + s + t + u + v + w + x + y + z + aa + bb + cc + dd + ee + ff + gg + hh + ii + jj + kk + ll + mm + nn + oo + pp + qq + rr + ss + tt + uu + vv + ww + xx + yy + zz + aaa + bbb + ccc + ddd + eee + fff + ggg + hhh + iii + jjj + kkk + lll + mmm + nnn + ooo + ppp + qqq + rrr + sss + ttt + uuu + vvv + www + xxx + yyy + zzz + aaaa + bbbb + cccc + dddd + eeee + ffff + gggg + hhhh + iiii + jjjj + kkkk + llll + mmmm + nnnn + oooo + pppp + qqqq + rrrr + ssss + tttt + uuuu + vvvv + wwww + xxxx + yyyy + zzzz + aaaaa + bbbbb + ccccc + ddddd
Results 1 to 1 of 1
crack region code on avi files to burn to dvd
By wilbureduke in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2010, 21:12 -
sony DAV-HDX589W multi code zone code
By sam1821 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th May 2010, 15:37 -
fix Mp4 (Mov) files - binary/hex code
By octopus in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2010, 17:00 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
Putting time code on AVI files
By snap25 in forum MacReplies: 1Last Post: 24th Nov 2007, 21:15
