Thread: GSpot and Mediainfo Help
Like most apps; top left menu "File/Open" then browse for it.
or easier; run the app and drop a file on it.
If you're just asking about opening files in either GSpot or MediaInfo, you can drag-and-drop videos onto either program's window, and the information should change (as Chris K mentioned). Also, you can add them to Windows' Send To menu, so that you would be able to right-click on a video, pick Send To > GSpot or MediaInfo, and that would open either program with the information on the video.
You probably downloaded the command line version.Originally Posted by swampwizard
There's also a GUI version of mediainfo available. See on the left at "Tools".
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 22:22 -
[MediaInfo] What exactly is bitrate ?
By Klagar in forum Video ConversionReplies: 2Last Post: 3rd Nov 2010, 09:54 -
TC in MediaInfo?
By dnc in forum Newbie / General discussionsReplies: 4Last Post: 8th Feb 2010, 10:53 -
MKV and mediainfo
By stiltman in forum DVD RippingReplies: 6Last Post: 14th Sep 2009, 22:36 -
What parameter in Gspot or MediaInfo shows if AVI will play in DVD player?
By jimdagys in forum Video ConversionReplies: 6Last Post: 19th Apr 2009, 01:58
