Hello,
I play WMV files on Media Player Classic (works better than VLC for WMV)
I had version 6.4.9.1 from the K-Lite Codec Pack.
But recently the playback started to get jumpy/hashed instead of going smoothly (I don't know how to explain and I hope you know what I mean).
I decided to install Media Player Classic HomeCinema v1.1.604.0.
When I open a file from the player it now plays fine.
But when I try to open a file from the explorer, MPC opens but then it says "File Not Found"
Can someone please help me.
My OS is XP Pro SP2
right click on what you want to open. select open with. choose program/browse. navigate to where you installed mpch. select the .exe, and close. it should now be able to locate the program to open the file with.
Thanks minidv2dvd
The problem is not in locating the program. When I click on the video file, MPCHC opens without any problem.
But then there is the message at the bottom of the player as shown on the attached picture.
I had the same problem and I solved it by:
1 Open Folder Options under Tools in Windows Explorer.
2 Select the File Types tab
3 Scroll down and click on the file type (in my case it was m2v)
4 Click Advanced
5 Click New
6 Under Action enter "Play with MPCHC" (without the quotes)
7 Click Browse, locate and 'open' the program (mplayerc.exe)
8 Click OK
9 Click OK
10 Close Folder Options.
After doing the above, when you right click the file you should have the option "Play with MPCHC" in the dropdown."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
I have had this problem with Media Player Classic on several computers. What happens is that when you associate the file type, say MOV, with MPC, Windows creates the line "C:\Program Files\MplayerClassic\mplayerc.exe" %1 where %1 means the file being clicked. For some reason that does not work with MPC but if you enclose the %1 in parenthesis the command will work: "C:\Program Files\MplayerClassic\mplayerc.exe" "%1".
'Hope that helps.
The former wouldn't work if there were spaces in the path. Because space is a delineator in command line arguments.Originally Posted by fontana
Great, solved the same problem for me - exactly as stated! Thanks fontana!Originally Posted by fontana
Playing subtitles off VOB file in Media Player Classic
By aduh11 in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2009, 15:44 -
Solved: How to play AAC file with Media Player Classic
By jimdagys in forum AudioReplies: 8Last Post: 17th Sep 2009, 07:32 -
Cue File With Media Player Classic 64
By mugly78643 in forum AudioReplies: 1Last Post: 2nd Jun 2009, 04:42 -
Problem playing a .mov file with Media Player Classic - No audio
By shiningwizard in forum Software PlayingReplies: 4Last Post: 20th Sep 2008, 07:52 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49
