I have made several attempts to include a Farsi subtitle into mkv file with mkvmerge. However I can’t seem to find a suitable Charset code under Format Specific Options -> Subtitle Charset to display the subtitle correctly. The Arabic Charsets do display the alphabet but not in correct format.
Any direction is appreciated it.
Thread: Farsi/Persian MKV merge
Use Notepad for converting the Farsi subtitle into a UTF-8 or Unicode file.
MKVmerge should accept that without a problem.
Midzuki Thanks for the response. I save the file both in UTF-8 and Unicode but unfortunately both times the end results was unrecognized characters in MKV. Although the same file would display correctly in the Subtitle creator. The file is in SRT format.
However at the end I found a solution:
I saved the file in the subtitle creator in idx format. During the save process subtitle creator asked me for encoding format and I chose Persian.
I then merged the idx file into mkv container and everything is working file now.
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 03:42 -
MKV Extract and Merge
By b1tbull in forum DVD RippingReplies: 2Last Post: 24th Aug 2010, 04:50 -
Merge MKV Chapters??
By ron spencer in forum DVD RippingReplies: 2Last Post: 12th Sep 2009, 18:31 -
mkv merge
By runLoganrun in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2008, 06:53 -
MKV Merge subtitle error
By zzyzx2 in forum SubtitleReplies: 2Last Post: 1st Jun 2008, 23:44
Statistics
Newest guides
Latest tool updates
New media comments
