i wanted to know which is good HDD camcorder or DV camcorder. What are the advantages and disadvantages .
If i make movie with the HDD camcorder will i be able to copy it faster to my computer using Firewire.
FireWire from a DV camera, HD or not, will still copy in real time. 1 hour of video takes 1 hour to transfer.
If you are asking about a hard drive camcorder, they use other formats than DV most times. Usually MP4 or MPG. They may transfer faster, at a lower quality, but not through FireWire, AFAIK. Very high end cameras may use different transfer methods and DV or better, but big $$$.
And tapal, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
Here is the current ratings list from camcorderinfo.
http://www.camcorderinfo.com/ratings.php#
After reading through that, ask again with some description of your needs.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
which one will u suggest HDD cam or DV cam. Which is good in picture and sound quality. Can i make DVD with MP 4 format.
DV tape camcorders still seem to be the best value for the money. HD (High Definition) camcorders are also now common, so you have that option also. If your final output is DVD with good quality, I would consider a regular DV tape camcorder.
The other common options are a MPEG camcorder, some burning to a mini-DVD disc, and others to a hard drive (HDD). More common for hard drive camcorders is using a MP4 format. Most times a DV tape camcorder is better quality. A mini-DVD camcorder does has the advantage of DVD ready MPEG files, but is not as good for editing as DV and is lesser quality than DV. MP4 is not good for editing.
JMO.
never trust a hardrive for storage .miniDv is safer and for long term storage is better
what software for sony hdd camcorder
By ballboy in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 11th Dec 2008, 14:26 -
HDD VS Flash VS miniDV camcorder. Which is better?
By vid83 in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 11th Dec 2008, 09:11 -
No sound playback on copied files from HDD Camcorder
By syberkill in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 10th Nov 2008, 00:11 -
will hdd camcorder work with premiere?
By aj8690 in forum Camcorders (DV/HDV/AVCHD)Replies: 11Last Post: 28th Apr 2008, 04:06 -
Corrupt HDD Camcorder recordings ? Need content, ideas appreciated
By PushPull in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 11th Dec 2007, 02:07
