VideoHelp.com Forum
    I just bought this media player (along with the plugin that supports H.264) but my video files will not play on it, the only thing I can think of is that the player's supported resolution is 800x400 but my vids are slightly larger 848x480 is there anyway i can convert them to the next lowest resolution to play on my player?
  2. here are the specs with the plugin.
    With optional software plug-in:
    HD support: MPEG-4 (ASP 720p) & WMV HD (MP 720p)
    MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound (5.1)
    H.264 up to DVD resolution with AAC
    make sure the video and audio are both in spec - you should be using 720x480 using h.264 with aac.
    According to VLC media player the audio is mpga is there any way i could convert that to AAC without too much hassel
  4. you probably need to re-encode both the video to the proper size and the audio to the proper type. if you don't have any encoders then maybe give avidemux a try as it may be able to do both for you. megui is another option that may work.
  5. Always Watching guns1inger's Avatar
    Try MediaInfo to confirm exactly what it is, as VLC tends to use mpga as a fallback for anything it can't work out correctly
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    MediaInfo says this:
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : H264
    Duration : 1h 32mn
    Bit rate : 924 Kbps
    Width : 768 pixels
    Height : 432 pixels
    Display aspect ratio : 16/9
    Frame rate : 23.976 fps
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Codec ID : 55
    Codec ID/Hint : MP3
  1. Replies: 6
    Last Post: 12th Sep 2010, 14:29
  2. Archos 605 Video Encoding
    By DJboutit in forum Video Conversion
    Last Post: 27th Dec 2009, 14:38
  3. Replies: 2
    Last Post: 5th Nov 2009, 23:41
  4. Archos 605 Audio-Video Synchronization Issues
    By analein in forum Portable Video
    Last Post: 31st Aug 2008, 13:27
  5. help with my archos 605
    By mustang1967 in forum Video Conversion
    Last Post: 27th May 2008, 21:43
