VideoHelp.com Forum
  1. Member Deter's Avatar
    Hello,
    Was wondering what chip needs to be pulled out to make this region free
    Also wondering what chip needs to be romoved to make the DVD recorder, record DVD back-ups of copy protected DVD's
  2. i'm afraid that all you are going to get if you remove any chips from the circuit board is a dead unit.
  3. Member victoriabears's Avatar
    I think dvd recorders are very difficult to make region free, you are better off getting a cheap dvd player that is or can be made region free, and just FYI dvd's recorded on a dvd recorder or even a burner I think, are not region encoded?
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  4. Member Deter's Avatar
    I was just wondering on the Region Free thing, cause I have one also, it is a samsung, and I thought they pulled out a chip or something, cause on the box it says region 1.
    But I was really wondering about the coding on the DVD's that makes the DVD recorder not record, how do I bypass that.
    It isn't possible to bypass copy protection by hacking a DVD recorder's firmware or modifying its hardware.
    Why else do you think that the Google searches you presumably did before posting here turned up nothing?
    Removed
  1. Panasonic DMR-EZ27 and EZ28 switches channels while recording
    By dtsb52 in forum DVD & Blu-ray Recorders
    Last Post: 2nd Jul 2009, 11:59
  2. Panasonic DMR-EZ27 has lost its digital tuning capability
    By Frank-0-Video in forum DVD & Blu-ray Recorders
    Last Post: 23rd Feb 2009, 17:26
  3. Panasonic DMR-EZ27 recording audio problem
    By manlok in forum DVD & Blu-ray Recorders
    Last Post: 6th Mar 2008, 21:02
  4. panasonic dmr-ez27 and fixed hybrid vbr resolution ?
    By hamilton accie in forum DVD & Blu-ray Recorders
    Last Post: 20th Jan 2008, 16:41
  5. Panasonic LSI for DMR-EZ17,EZ27...?
    By cosmin in forum DVD & Blu-ray Recorders
    Last Post: 18th Aug 2007, 21:17
