Hello folks,
I have an mkv (720p x264) file that I like to transform to a DVD with DVD Flick. But I am troubled by the two options that I wrote in the header. What is the difference?
Mark
Most likely NTSC means a frame rate of 29.97 frames per second and NTSC-movie means a frame rate of 23.96 (or 24) framers per second. I'd use whichever one matches your source MKV frame rate.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum CapturingReplies: 33Last Post: 28th Nov 2013, 11:33 -
NTSC DV from Final Cut Pro to NTSC DVD Problems
By Killer3737 in forum Video ConversionReplies: 1Last Post: 9th May 2011, 12:25 -
NTSC VHS to NTSC DVD
By alir77 in forum RestorationReplies: 8Last Post: 8th Jan 2011, 04:32 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
