VideoHelp.com Forum
    I am archiving a very old VHS tape
    Mapletown.
    It seems to act like its MV encoded though
    I did not see any of the telltale white flashing
    lines in the vertical blanking interval, and it
    was not flashing bright-dark-bright-dark
    it was simply fading from normal to bright
    and back to normal then fading to bright
    again.
    I tried the search function but it won'
    t tell me anything.
    Should I just use a Macrovision remover or
    invest in a time base corrector?
    I am not sure if this is MV encoded,
    it does not say in the video or on the
    box, but it acts a little like it is encoded
    but not the typical bright-dark flashing
    and it is NOT very dark and weak like
    MV its just normal then fades to bright
    then back to normal and fades to bright
    again, sometimes erratically and not
    as even pattern thingy
    Equipment used in the capture are
    a Datavideo DAC 200 and a Miglia
    Director's cut II tried both,
    VHS machine is a JVC Super VHS
    capable machine, HR-S5902U
    capturing to mac mini 2Gb ram
    ox x tiger 10.4 in the usa on
    110V power. Tried capturing with
    quicktime's DV record movie,
    and final cut pro.
    Sorry I have Asperger's and I don't
    communicate well.
    Forgive my handicap.
    Thank you for all the kind answers
    I get.
  2. I'm a Poll Super Moderator johns0's Avatar
    Looks like it has mv,old mv just faded from normal to dark continouosly..The Datavideo DAC 200 should compensate for it,might wanna try a tbc then if its just a poor video signal.
    Ben Johnson-I didnt take any stereos!
    yup that's how I always saw MV on PAL systems (I grew up in Australia).
    if you haven't captured yet I'd do what we did back in the 90's. We got a universal PAL<>NTSC converter box. It took the MV out in process. It has slide switches so you could do NTSC->NTSC PAL->PAL etc.
    look on eBay etc they are a little plastic box that looks like a modem.
    btw, the way MV works is that it puts a signal in the calibration zone ( in the Vertical Blanking Interval as you mentioned) that is WAY too high then WAY too low. It turns out that TVs ignore that reference and use their own 1v p-p reference. VHS recorders and now capture cards know that the source could be weak so they do rely on the reference. Give a high reference and the image gets dark, give a low reference and it gets bright.
    SO.. that's how it worked.
    If you capture with that and then want to fix it the damage to the image is already done, whites and blacks are clipped.
    The software you use to capture is already too late in the process. You either have to get a capture card that has a ignore-macro vision capability OR you need to get a box like the converter I mentioned above that ignores it too.
    good luck!
    If the tape you have is from the children's cartoon series "Mapletown", it may or may not be an MV problem. It was released on the FHE label, which rarely bothered with MacroVision, although the series was licensed by Nickleodeon which may have asked for MV protection. Its very rare in the USA to find an MV protected tape which does not show the little tell-tale squares in the blanking interval: there were many different versions of MV, some pulsed very slowly and some blinked rapidly, but ALL will show the squares in the VBI. If you see nothing there but a black bar, then MV is likely not your problem. You would need an external TBC or "video filter" to get rid of any MV coding, and such devices are not cheap. If this is the only tape you expect to encounter this problem with, it may be more cost-effective to simply purchase the four DVD set for $25 on the iOffer site.
  1. macrovision copy
    By Blackband in forum DVD & Blu-ray Recorders
    Last Post: 24th Jul 2011, 14:43
  2. Macrovision Question
    By matthewjohn23 in forum DVD & Blu-ray Recorders
    Last Post: 7th Jun 2011, 15:19
  3. Macrovision like NONE OTHER
    By blacksheepdownunder in forum Capturing
    Last Post: 22nd Jul 2010, 04:16
  4. Macrovision
    By adamrose in forum Newbie / General discussions
    Last Post: 22nd May 2008, 20:41
  5. Macrovision Help!
    By dollydoodledumplin in forum DVD & Blu-ray Recorders
    Last Post: 24th Nov 2007, 10:37
