Hi,
I was wondering if someone could help me with a problem I am having with Windows Movie Maker, I have had problems in the past with Movie Maker not recognising .avi footage down loaded direct from the camera using Ulead Photo Explorer then importing them to the Movie Maker program, files have been eventually recognised after some stuffing around using a SD card reader, tonight I am trying once again to import avi files but keep getting a error message and the Movie Maker programs shuts down, very frustrating..
Can anyone suggest something that might help..
Nick..
Start by identifying exactly what the video is. Movie Maker works with only a small range of types. AVI, as a container format, can contain many more formats than movie maker can handle. The solution may mean installing an extra codec so movie maker can read it, or converting the video to something movie maker is more comfortable with. Until we know what you have, it is impossible to say what the best solution is.
Try mediaInfo or G-spot to see what is inside the avi file.Read my blog here.
Hi Guns1inger,
Thanks for your help, i used G-spot to tell me what is in the file.. I dont know what to look for so i'll try to give you the information on the screen..
Container..
File Length Correct
AVI v1.0
Video: 17.2 MB (96.98%)
Audio: 507 KB (2.78%)
AVI Overhead: 45.0 KB (0.25%)
Video
Code XVID
Name XviD ISO MPEG-4
Status Codec(s) are Installed
Hope you can work it out from that info..
Nick.. -
Hi Guns1inger,
I think i might have found the problem, i was looking at the settings for WMM and unchecked a few boxes in the Tools, Options, Filters tab and now the footage seams to be running on WMM as it used to last week.
Thanks for your help, you gave me an idea to check the settings with the files WMM uses..
Nick..
How Do I Convert an MP4 file to Windows Movie Maker format?
By gasjkh22 in forum AudioReplies: 7Last Post: 28th Aug 2011, 05:13 -
Windows movie maker problem
By Psco2007 in forum Newbie / General discussionsReplies: 12Last Post: 8th Jun 2010, 11:42 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 19:11 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 10:37 -
Windows Movie Maker, does not except this file format help??
By Tripletmomplus2 in forum Newbie / General discussionsReplies: 4Last Post: 31st Jul 2007, 19:54
