I don't remember what verison of PSPEnc I have, but it can't be more than 2 weeks old.
Anyway I converted some plain vanilla avi xvid mp3 files using PSPEnc and I'm getting audio desync. The source videos are synced properly. I thought it was a FPS conversion issue so I converted again using changeFPS and then convertFPS but it didn't fix the problem.
The only thing different with these 2 videos that have this issue is that I used mediacoder to convert them to a format that PSPEnc can handle (it doesn't like mkv with raw h264 streams or .mp4 files), so maybe that's something, I dunno.
Thanks in advance for any help.
it might have vbr mp3 audio. demux and convert to cbr or wav before encoding with pspenc.
Hrm, well I did convert the files with Mediacoder, so I would think they would already be cbr, but I'll check again. I also read somewhere on another forum that another audio desync cause can be improper frame rate. Thanks.Originally Posted by minidv2dvd
Audio desync after a while on Mpeg TS
By Liss0 in forum Video ConversionReplies: 0Last Post: 14th Jul 2011, 06:05 -
Audio desync problems when capturing with Fraps
By ecjezl in forum CapturingReplies: 4Last Post: 29th Jun 2011, 22:48 -
BIggg audio desync help!
By iamtrojan3 in forum AudioReplies: 1Last Post: 17th Jul 2009, 02:05 -
Audio desync in Autogk
By godfist314 in forum DVD RippingReplies: 3Last Post: 5th Sep 2008, 10:22 -
Getting audio desync problem when ripping with DVDFab Platinum 4
By godfist314 in forum DVD RippingReplies: 2Last Post: 8th Jul 2008, 13:50
Statistics
Newest guides
Latest tool updates
New media comments
