VideoHelp.com Forum
  1. Member lifesajrny's Avatar
    Looking for a audio software that will let you edit in real time. I would like to be able to hear the sounds when I apply filters, tools, equalization, ect....in real time.
    I'm converting wma files to burn on cd.
    Has anyone tried Magix Audio lab?
  2. Member unclebud's Avatar
    If you have and editor that supports VST or DX plugin's your set.
    Or
    Try Audacity, it's FREE
    It does not do real time effects though.
    http://audacity.sourceforge.net/download/windows
  3. Member Soopafresh's Avatar
    Wavelab will let you hear effects as you apply them. Not free, however.
    http://www.musiciansfriend.com/produ...LAID=145101654
    Foobar2000 has a VST module which allows you to use high quality VST plugins which you can hear in realtime
  1. Need Software Recommendation
    By JFolk in forum Newbie / General discussions
    Last Post: 11th Jun 2010, 08:23
  2. Software recommendation
    By pcfitness in forum Authoring (DVD)
    Last Post: 2nd Nov 2008, 21:13
  3. Software recommendation
    By Haopengyou in forum Newbie / General discussions
    Last Post: 8th Jan 2008, 07:28
  4. Software recommendation?
    By zeno in forum Authoring (DVD)
    Last Post: 28th Dec 2007, 11:48
  5. Software recommendation
    By statman24 in forum Newbie / General discussions
    Last Post: 13th Sep 2007, 11:50
