I use a TSST/Samsung and a plextor PX-755A burner, and TYG02 discs. Recently, If I burn on the Samsung from the Plextor, the burn is fine, If I burn on the Plextor from the Samsung I get a 'burn failed-power calibration error'. I am thinking that this may be a firmware issue, and the firmware on the Plextor is V1.01. I see on the Plextor firmware site that there is a version 1.08. Is this thinking/issue correct that it may be the firmware issue ?, AND, as i have never done a firmware update before, How do I do it ? what do I do with the selfextracting file V1.08 to update ? thanks.
Are you sure its a selfextracting. If you run it, it asks if you are you want to install the firmware upgrade. I would think if you check yes, it would install it.
See the FACs on their Web site.
GeorgeThe Second Amendment:
AMERICA'S ORIGINAL
HOMELAND SECURITY
GE DV1 No Firmware Update What Is Up??
By DJboutit in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2011, 22:16 -
WD TV Live: New 1.01.17 firmware update available
By MJA in forum Media Center PC / MediaCentersReplies: 31Last Post: 30th Jan 2010, 20:42 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 13:52 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 08:50 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46
Statistics
Newest guides
Latest tool updates
New media comments
