Hello,
I just replaced my DVD burner with the Pioneer 116D (upon Budz's recommendation in another thread)
No installation problem, Burning fine (with ImgBurn) but when verifying there is a parasite noise in the speakers, Play back is also fine but there is still that noise. It did not happen with my previous burner nor does it with my DVD rom.
I checked the connections but they seem ok.
Any idea what the problem is?
Another issue is that Disc Quality in Nero DiscSpeed failed: "This drive does not support this function".
Since I am running XP and I do not have a separate sound card, i just had to un-plug the audio cable.
Thanks to MysticEyes @ Cd-Freaks
Cant you verify the burn in a different drive? that may also give a truer reflection of the burn quality.. Are you talkng about the audio cable that allows direct playing of CD's into headphones?
The electronic components of the power part adopted a lot of Rubycons.
PC Speakers, which ones?
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 28th Sep 2011, 14:41 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 09:55 -
Noise problem: Pioneer BDC-202BK
By Kim Jespersen in forum DVD & Blu-ray WritersReplies: 5Last Post: 26th Apr 2008, 04:30 -
2 PC's, 1 Set of speakers
By SIRCOOKS in forum ComputerReplies: 15Last Post: 12th Feb 2008, 16:56
Statistics
Newest guides
Latest tool updates
New media comments
