VideoHelp.com Forum
    I'm using a Sonicview PVR receiver with dishnetwork. Wen the receiver records a show and i play back the file it allows me to fastforward and rewind the video. But when I convert a file using Xilsoft Video converted ultimate it plays the file but does not allow me to fastforward or rewind the file.
    I'm kind of new to th is please let me know if any other information is needed.
    File format receiver makes is .TS
    Video
    Mpeg2Video
    544X480
    29.97 framerate
    Audio
    mp2
    160 Bitrate
    48000 sample rate
    channels 2
    If there is any general suggestion to allow the Xvid file that i convert to .TS to fastforward/rewind on my PVR receiver please help.
    Can you post all details from the ts using mediainfo?
    I would try another mpeg2 converter like hcenc, tmpgenc. And then multiplex the mpg to a ts using tsmuxer.
    Or you just have to adjust the i-frames mpeg2 settings in xilisoft converter.
    Ok sorry for the late response.
    Here is the stats for the file i converted. It was a regular Xvid file. Convert it to .TS using TmpegXpress 4.0. I tried to get as similar to the file that the receiver outputs wen i record a show. (The file the receiver outputs is able to rewind and fast forward.)
    General
    Complete name : C:\Documents and Settings\Snake\My Documents\271.ts
    Format : MPEG-TS
    File size : 608 MiB
    Duration : 4mn 58s
    Overall bit rate : 17.1 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, Matrix : Standard
    Duration : 4mn 58s
    Bit rate mode : Constant
    Bit rate : 16.2 Mbps
    Nominal bit rate : 15.0 Mbps
    Width : 544 pixels
    Height : 480 pixels
    Display aspect ratio : 4/3
    Frame rate : 29.970 fps
    Standard : NTSC
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 1.917
    Writing library : TMPGEnc XPress 4.5.1.254
    Audio
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Duration : 4mn 58s
    Bit rate : 160 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Now this is the file that the Receiver outputs to my external DVD. Keep in mind t his file is able to fastforward/rewind
    General
    Complete name : C:\Documents and Settings\Snake\Desktop\Law Order Special Victims Unit [040908-003538].ts
    Format : MPEG-TS
    Format profile : No PAT/PMT
    File size : 80.0 MiB
    Duration : 2s 367ms
    Overall bit rate : 284 Mbps
    Video
    Format : MPEG Video
    Duration : 2s 367ms
    Bit rate : 15.0 Mbps
    Width : 544 pixels
    Height : 480 pixels
    Colorimetry : 4:2:0
    Audio
    Format : MPEG Audio
    Bit rate : 160 Kbps
    Video delay : -268ms
    Questions....
    Do you see anything in both files that would prevent my conversion from not rewinding/fastforwarding?
    Wat exactly is the Bframe, pframe etc. Would would allow for fastforward/rewind.
    Also the file that the receiver outputs also has a .IDX and a .IFO file that goes with it. Could something with-in these files make it able to rewind/fastforward???
    Any help with this would be greatly appreciated. Thanks
  1. Replies: 4
    Last Post: 24th Aug 2011, 14:54
  2. MKV Fastforward Hand Break
    By leftspeaker2000 in forum Newbie / General discussions
    Last Post: 7th Apr 2011, 09:28
  3. WMC in win 7 - fastforward & rewind
    By smounche in forum Software Playing
    Last Post: 18th Nov 2009, 09:52
  4. Cannot rewind FLV-video after conversion...
    By Frontman in forum ffmpegX general discussion
    Last Post: 10th Feb 2008, 10:28
  5. Replies: 3
    Last Post: 23rd Jul 2007, 21:48
