VideoHelp.com Forum
    On my hard drive, I have a file that is supposed to have subtitles. There is an AUDIO_TS folder, a VIDEO_TS folder (containing the IFO, BUP, and VOB), and there is a small srt file. When I play the file in VLC, there are no subtitles.
    First question, How do I get the subtitles to show up when I play the file? Do I have all the needed files, or am I missing something?
    Second question, Assuming that I have all the files and that nothing else is amiss, Is it possible to burn a DVD that will have subtitles when I play the DVD on the computer or on a stand-alone DVD player?
  2. to put srt subs into a dvd you will need to re-author it. use dvdlab pro, import the vobs and srt. here's a thread on adding the subs.
    http://www.videohelp.com/forum/archi...o-t332306.html
    I found Baldrick's guide to be very useful in getting started. However, the process reaches a point where it stops and tells me that the VobBlanker process can not be started because the specified file can't be found. What file is it looking for? And what do I need to do?
  4. It's looking for the VIDEO_TS.IFO. It's not actually looking for it. You point to it via File->Open DVD. Once you're in and want to replace the old video with the new one with the new subs, then you go Replace->VIDEO_01_0.IFO, scrolling to the VIDEO_01_0.IFO from your new Muxman authored DVD, the one with the new subs.
  1. Trying to burn an mkv with subtitles, but the subtitles don't burn properly
    By geramul in forum Newbie / General discussions
    Last Post: 1st Sep 2010, 19:12
  2. Replies: 15
    Last Post: 17th Mar 2010, 12:49
  3. How can i burn a DVD or VCD with subtitles?
    By Krimoon in forum Newbie / General discussions
    Last Post: 25th May 2008, 15:41
  4. Burn DVD Widescreen with subtitles
    By rvlira in forum Authoring (DVD)
    Last Post: 24th Oct 2007, 05:53
  5. trying to burn dvd with subtitles
    By Sugaface in forum ffmpegX general discussion
    Last Post: 29th Jul 2007, 23:54
