I have been using this burner for awhile so I think i may have burned it out. I figured I'd check to see if there was a better answer then spending more money on a new burner. (Yes, I am cheap!)
here is the nero log it looks like the main error is (-1135)
thanks in advance for the help!
1K22-1867-0795-66M4-5988-8643-****
4C01-K0A2-98M1-25M9-KC67-E276-****
EC06-206A-99K5-2527-940M-3227-****
9C00-E0A2-98K1-294K-06XC-MX2C-****
4C04-5032-9953-2A16-09E3-KC8M-****
EC05-E087-9964-2703-05E2-88XA-****
5C0X-205M-99M1-2435-2118-K246-****
4C0E-4009-9863-2X6M-1939-12A1-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.2.1
Internal Version: 8, 3, 2, 1
Recorder: <PIONEER DVD-RW DVR-112D>Version: 1.24 - HA 1 TA 0 - 8.3.2.1
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default
CD-ROM: <HITACHI DVD-ROM GD-7000 >Version: 016J - HA 1 TA 1 - 8.3.2.1
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVR-112D atapi Port 2 ID 0 DMA: On
CdRomPeripheral : HITACHI DVD-ROM GD-7000 atapi Port 2 ID 1 DMA: On
DiskPeripheral : WDC WD1600AAJB-00PVA0 atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-112D G: CdRom0
HITACHI DVD-ROM GD-7000 H: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1046956kB)
Free physical memory: 463MB (474148kB)
Memory in use : 54 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.9.2008
Burn DVD Image
3:06:22 PM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
3:06:22 PM #2 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
3:06:23 PM #3 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2199567 (488:47.42, 4296MB)
3:06:23 PM #4 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
3:06:23 PM #5 Text 0 File DlgWaitCD.cpp, Line 2932
Recorder: PIONEER DVD-RW DVR-112D, Media type: DVD-R
Disc Manufacturer ID: <SONY16> <D1>
Disc Application Code: 64, Disc Physical Code: 193
3:06:23 PM #6 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
3:06:23 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2199568 (2199568) = #2199568/488:47.43
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2199568 blocks [G: PIONEER DVD-RW DVR-112D]
3:06:23 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [G: PIONEER DVD-RW DVR-112D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4504715264, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2199568 | 2199568 | 0x00
2199568 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
3:06:25 PM #9 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
3:06:25 PM #10 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
3:06:25 PM #11 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
3:06:25 PM #12 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
3:06:25 PM #13 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
3:06:25 PM #14 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11,080 KB/s)
3:06:28 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
3:06:28 PM #16 Text 0 File DVDR.cpp, Line 3280
Recording mode: Sequential Recording Mode
3:06:28 PM #17 Text 0 File DVDR.cpp, Line 3434
Start write address at LBA 0
DVD high compatibility mode: Yes
3:06:28 PM #18 SPTI -1066 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x04bdb6c0: Len x648
3:06:28 PM #19 Text 0 File Cdrdrv.cpp, Line 10164
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0E 10 87 88 80 00 .@....R.........
03 53 4F 4E 59 31 36 00 - 04 44 31 00 00 00 00 00 .SONY16..D1.....
05 88 80 00 00 00 01 00 - 06 09 0B 12 A8 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 06 13 0A 0E 08 04 00 ................
09 96 06 0C 0B 70 88 00 - 0A 80 00 00 00 00 10 00 .....p..........
0B 08 18 17 B8 88 85 00 - 0C B6 79 0B B0 33 03 00 ..........y..3..
0D 30 00 D0 00 00 00 00 - 0E 0A 20 3B 37 29 1E 00 .0.........;7)..
0F 50 1D 2B 15 AA B5 00 - 10 88 80 00 00 00 00 00 .P.+............
11 00 00 00 00 00 00 00 - 12 0A 2D 39 35 2B 1D 00 ..........-95+..
13 50 1F 2D 19 98 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
15 00 00 00 00 00 00 00 - 16 09 3A 45 40 2E 27 00 ..........:E@.'.
17 80 21 2E 1F 78 B5 00 - 18 88 8C 00 0C 00 0C 00 ..!..x..........
19 00 00 00 00 00 00 00 - 1A 09 4F 47 46 38 26 00 ..........OGF8&.
1B 70 21 2D 1B 67 C5 00 - 1C 88 84 00 04 00 04 00 .p!-.g..........
3:06:28 PM #20 Text 0 File DVDR.cpp, Line 3572
Reserved Track size: 2199568 (219010h, 4296MB) -> return code 0
3:06:28 PM #21 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
3:06:29 PM #22 Text 0 File Cdrdrv.cpp, Line 1404
15:06:29.750 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #23 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.812 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #24 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.828 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #25 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.843 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #26 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.859 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #27 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.875 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #28 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.890 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #29 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.906 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #30 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.921 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #31 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.937 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #32 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.953 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #33 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.968 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:21 PM #34 Text 0 File Cdrdrv.cpp, Line 1404
15:07:21.984 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #35 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.000 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #36 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.015 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #37 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.031 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #38 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.046 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #39 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.062 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #40 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.078 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #41 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.093 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #42 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.109 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #43 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.125 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #44 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.140 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #45 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.156 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #46 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.171 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #47 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.187 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #48 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.203 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #49 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.218 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #50 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.234 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #51 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.250 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #52 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.265 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #53 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.281 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #54 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.296 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #55 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.312 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #56 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.328 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #57 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.343 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #58 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.359 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #59 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.375 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #60 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.390 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #61 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.406 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #62 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.421 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #63 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.437 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #64 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.453 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #65 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.468 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #66 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.484 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #67 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.500 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #68 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.515 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #69 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.531 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #70 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.546 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #71 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.562 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #72 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.578 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #73 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.593 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #74 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.609 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #75 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.625 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #76 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.640 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #77 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.656 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #78 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.671 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #79 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.687 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #80 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.703 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #81 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.718 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #82 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.734 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #83 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.750 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #84 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.765 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #85 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.781 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #86 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.796 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #87 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.812 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #88 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.828 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #89 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.843 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #90 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.859 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #91 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.875 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #92 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.890 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #93 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.906 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #94 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.921 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #95 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.937 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #96 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.953 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #97 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.968 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:22 PM #98 Text 0 File Cdrdrv.cpp, Line 1404
15:07:22.984 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #99 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.000 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #100 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.015 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #101 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.031 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #102 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.046 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #103 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.062 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #104 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.078 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #105 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.093 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #106 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.109 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #107 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.125 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #108 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.140 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #109 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.156 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #110 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.171 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #111 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.187 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #112 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.203 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #113 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.218 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #114 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.234 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #115 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.250 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #116 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.265 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #117 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.281 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #118 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.296 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #119 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.312 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #120 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.328 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:07:23 PM #121 Text 0 File Cdrdrv.cpp, Line 1404
15:07:23.343 - G: PIONEER DVD-RW DVR-112D : Queue again later
3:13:46 PM #122 SPTI -1135 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
CDB Data: 0x2A 00 00 1E 63 80 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x71 00 03 00 1E 60 B0 0E 00 00 00 00 0C
Buffer x0b0cdf40: Len x10000
0x00 00 01 BA 45 B8 5D F2 1D 57 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 FD 07 04 24 3A 02 A9 61 BB
0x7D F9 A4 E8 B4 A0 B5 B7 FB 2D 18 9F 17 DD 3C 0B
3:13:46 PM #123 CDR -1135 File Writer.cpp, Line 306
Write error
3:13:46 PM #124 Text 0 File DVDR.cpp, Line 3840
EndDAO: Last written address was 1991551 (1E637Fh)
3:13:46 PM #125 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11,080 KB/s)
3:13:46 PM #126 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
3:13:49 PM #127 Text 0 File Cdrdrv.cpp, Line 11420
DriveLocker: UnLockVolume completed
3:13:49 PM #128 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
try imgburn and a different dvdr brand. preferably verbatim or taiyp yuden dvd-r. looks like it could be bad media.
If you still have existing problems when using IMGBURN then do a burst rate test using CD/DVD SPEED. Then post the results here.
http://www.cdspeed2000.com/download.html#nerocdspeed
The Sony dvd media that you're using should be fine. Another suggestion is to buy a new 80 wire ide cable because they can fail after a period of time.
I tried cleaning out the DVD DRive with an air can and it worked for a MAXELL DVD-RW disc so I tried another Sony disc and got this problem:
I 16:24:58 Operation Started!
I 16:24:58 Source File: E:\HOF Putski 2.ISO
I 16:24:58 Source File Sectors: 2,199,568 (MODE1/2048)
I 16:24:58 Source File Size: 4,504,715,264 bytes
I 16:24:58 Source File Volume Identifier: HOF Putski 2
I 16:24:58 Source File Volume Set Identifier: 391748A4C6E8B75B
I 16:24:58 Source File Application Identifier: NERO BURNING ROM
I 16:24:58 Source File Implementation Identifier: Nero
I 16:24:58 Source File File System(s): ISO9660, UDF (1.02)
I 16:24:58 Destination Device: [2:0:0] PIONEER DVD-RW DVR-112D 1.24 (G
(ATA)
I 16:24:58 Destination Media Type: DVD-R (Disc ID: SONY16D1) (Speeds: 4x, 6x, 8x, 12x, 16x)
I 16:24:58 Destination Media Sectors: 2,298,496
I 16:24:58 Write Mode: DVD
I 16:24:58 Write Type: DAO
I 16:24:58 Write Speed: 16x
I 16:24:58 Link Size: Auto
I 16:24:58 Test Mode: No
I 16:24:58 OPC: No
I 16:24:58 BURN-Proof: Enabled
I 16:24:58 Filling Buffer... (40 MB)
I 16:25:00 Writing LeadIn...
I 16:25:54 Writing Session 1 of 1... (1 Track, LBA: 0 - 2199567)
I 16:25:54 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2199567)
W 16:31:56 Failed to Write Sectors 2040992 - 2041023 - Reason: Write Error
W 16:31:56 Retrying (1 of 20)...
W 16:31:56 Retry Failed - Reason: Cannot Write Medium - Incompatible Format
W 16:31:56 Retrying (2 of 20)...
W 16:31:56 Retrying (3 of 20)...
W 16:31:57 Retry Failed - Reason: Cannot Write Medium - Incompatible Format
W 16:31:57 Retrying (4 of 20)...
W 16:31:57 Retrying (5 of 20)...
W 16:31:57 Retrying (6 of 20)...
W 16:31:57 Retrying (7 of 20)...
W 16:31:57 Retrying (8 of 20)...
W 16:31:57 Retrying (9 of 20)...
W 16:31:57 Retrying (10 of 20)...
W 16:31:57 Retrying (11 of 20)...
W 16:31:57 Retrying (12 of 20)...
W 16:31:57 Retrying (13 of 20)...
W 16:31:57 Retrying (14 of 20)...
W 16:31:57 Retrying (15 of 20)...
W 16:31:57 Retrying (16 of 20)...
W 16:31:57 Retrying (17 of 20)...
W 16:31:57 Retrying (18 of 20)...
W 16:31:57 Retrying (19 of 20)...
W 16:31:57 Retrying (20 of 20)...
E 16:32:12 Failed to Write Sectors 2040992 - 2041023 - Reason: Write Error
I 16:32:12 Synchronising Cache...
W 16:32:19 User opted to skip the 'Close Track/Session/Disc' functions.
E 16:32:19 Failed to Write Image!
I 16:32:19 Exporting Graph Data...
I 16:32:19 Graph Data File: C:\Documents and Settings\Thomas Doran\Application Data\ImgBurn\Graph Data Files\PIONEER_DVD-RW_DVR-112D_1.24_MONDAY-SEPTEMBER-01-2008_4-24_PM_SONY16D1_16x.ibg
I 16:32:19 Export Successfully Completed!
E 16:32:19 Operation Failed! - Duration: 00:07:21
I 16:32:19 Average Write Rate: 10,798 KB/s (7.8x) - Maximum Write Rate: 16,272 KB/s (11.7x)
i am off to run a burst rate test
I got this message while running the burst speed
[16:42:54] Drive: PIONEER DVD-RW DVR-112D 1.24
[16:42:55] Disc: DVD-R, 4.20 GB, SONY16D1
[16:43:11] Starting transfer rate test
[16:50:50] Error - L-EC UNCORRECTABLE ERROR (031105)
Here is a second test that looks to have completed:
[16:53:02] Starting transfer rate test
[16:58:38] Speed:5-11 X CAV (8.55 X average)
[16:58:38] Elapsed Time: 5:35
[16:58:38] Starting access times test
[16:58:52] Random Access: 135 ms
[16:59:07] 1/3 Access: 158 ms
[16:59:30] Full Access: 221 ms
[16:59:30] Elapsed Time: 0:52
[16:59:30] Starting CPU usage test
[16:59:45] CPU usage at 1X: 5 %
[17:00:00] CPU usage at 2X: 13 %
[17:00:31] CPU usage at 4X: n/a
[17:01:11] CPU usage at 8X: n/a
[17:01:11] Elapsed Time: 1:41
[17:01:11] Starting burst rate test
[17:01:13] Interface burst rate: 35 MB/sec (35859 KB/sec)
[17:01:13] Elapsed Time: 0:02
[17:01:13] Starting spin-up/down test
[17:01:17] Spin-up time: 1.37 seconds
[17:01:30] Spin-down time: 2.46 seconds
[17:01:30] Elapsed Time: 0:17
[17:01:30] Starting load/eject test
[17:01:31] Eject time: 1.39 seconds
[17:01:49] Load time: 17.97 seconds
[17:01:49] Recognition time: 0.01 seconds
[17:01:49] Elapsed Time: 0:19
IMGBURN is the best software for burning dvd media don't use NERO.
Check the UDMA settings for your 112D drive. It should be in UDMA 4 mode.
Are you using a 80 wire ide cable with your 112D drive? As I've already suggested buy a new 80 wire ide cable for your drive. This should determine whether or not you need to buy a new dvd burner. You can also get some VERBATIM or TAIYO YUDEN dvd media to try.
The burst rate test seems to be okay but a bit low. BRB gonna do a burst rate test on my PIONEER 111L drive. My burst rate is 40mb.
Pioneer DVR-112D connects but won't burn
By JessW in forum DVD & Blu-ray WritersReplies: 19Last Post: 30th Jun 2008, 23:41 -
DVD writer exchange for my Pioneer DVR-530H
By J.J.F in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 09:40 -
Does Pioneer DVR-112D burn DVD+R and DVD+R DL media well?
By palmtree in forum DVD & Blu-ray WritersReplies: 26Last Post: 4th Jan 2008, 03:22 -
Pioneer dvd-rw dvr-112D Driver Update
By scustalow in forum DVD RippingReplies: 1Last Post: 27th Jul 2007, 13:16 -
TYG03 burns at 18x in DVR-112D, only 4x in DVR-107D
By mikewillnot in forum MediaReplies: 1Last Post: 15th May 2007, 16:28
