Hi
my problem is that i cant encode any kind video
when I convert .wmv it gives me this error
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Wed Aug 27 22:06:58 AST 2008
0.00 (30/1)
Input #0, asf, from '/Users/Asma/Movies/hallooowma2.wmv':
Duration: 00:04:12.4, start: 3.000000, bitrate: 263 kb/s
Stream #0.0: Audio: wmav2, 22050 Hz, stereo, 32 kb/s
Stream #0.1, 30.00 fps(r): Video: WMV3 / 0x33564D57, 320x240
Incorrect frame rate
and when I encode real it gives me a zero byte file and this is the process information
[NULL @ 0x54340c]Unsupported video codec
Wed Aug 27 22:13:29 AST 2008
s/Asma/Desktop/baba.rm':
Duration: 00:03:57.8, start: 0.000000, bitrate: 1138 kb/s
Stream #0.0: Audio: cook, 44100 Hz, stereo, 64 kb/s
Stream #0.1, 12.00 fps(r): Video: RV40 / 0x30345652, 720x576, 796 kb/s
Stream #0.2: Data: 0x0000
Codec type mismatch for mapping #0.0 -> #0.0
I hope that you can help me and sorry for my bad writing because i cant speak english very will
Thread: can not encode any video
It is not easy to convert WMV and RM on Mac OS X, but let's try anyway.
The "Incorrect frame rate"-error could be related to how numbers are represented on your localization. Some countries use 30,00 (with a comma), some countries use "30.00" (with a point).Originally Posted by 1992girl
Check the video framerate setting in the Video tab. If it is empty, set a value. If it said "30.00" or "30,00", then change the value to "30" (without decimals) to match the source file. The preset framerates (NTSC FILM (23.976)/PAL (25)/NTSC (29.97)) are not effected by this issue.
ffmpegX can use one of three encoder engines: ffmpeg, mencoder or mpeg2enc. The error above shows that you were using an ffmpeg preset. You need to use a mencoder preset to convert RM files with ffmpegX. The ffmpeg engine is not able to convert RM files. In ffmpegX, use a target preset that has 'mencoder' in its name (h.264 mencoder, XviD mencoder or DivX mencoder).Originally Posted by 1992girl
The reason for this is that mencoder presets use mplayer to read the RM file, while ffmpeg presets do not use mplayer to read the file. And the reallib that is needed for RM is an mplayer plug-in.
Is there any video card that can encode/convert video at lightning speed?
By johnharlin in forum Video ConversionReplies: 11Last Post: 17th Mar 2012, 15:27 -
Video and audio did not encode what can I do?
By IYIasteI2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2011, 10:00 -
encode cuts video ?
By stefniamoo in forum ffmpegX general discussionReplies: 1Last Post: 25th Jul 2011, 13:25 -
Rotate Video - No re-encode?
By therock003 in forum EditingReplies: 2Last Post: 26th Jul 2010, 04:26 -
Re-encode video file
By KoRatta in forum Video ConversionReplies: 5Last Post: 10th Jul 2008, 09:36
Statistics
Newest guides
Latest tool updates
New media comments
