VideoHelp.com Forum
    After I use xilisoft video converter, the output's sound become bad(not like any language speaking).
    I installed latest K-Lite Codec Pack.
    When using Tmpgenc xpress 4.0, the output is ok! I can play mvk file with my jet audio player.
    Do I need to install aac code or any solution?
    General
    Complete name : E:\Torrent\Movie\www.tsxz.com3\[www.tsxz.com]°üÇàÌìÖ®°×Áú¾Ô03.ÉËÐÄÌìʹ.mkv
    Format : Matroska
    File size : 350 MiB
    Duration : 46mn 38s
    Overall bit rate : 1 049 Kbps
    Encoded date : UTC 2008-07-14 17:20:28
    Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 46mn 38s
    Nominal bit rate : 997 Kbps
    Width : 704 pixels
    Height : 432 pixels
    Display aspect ratio : 1.630
    Frame rate : 25.000 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.131
    Writing library : x264 core 60 r901M 58d7d06
    Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / rdcmp=psy / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=997 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : Yes
    Format settings, PS : Yes
    Codec ID : A_AAC
    Duration : 46mn 38s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    "I installed latest K-Lite Codec Pack"
    This is why you're having problems. Never use codec packs.
    Why not use tmpgenc xpress if it works?
    I convert for my friend. He say 3 or 4 hrs conversion too long.
    Xilisoft take 20 min only...
    any suggestion for AAC LC?
  5. Always Watching guns1inger's Avatar
    As I have already said in another post today - you can do fast, or you can do it right.
    FAVC, DVD Flick and ConvertxtoDVD will all convert MKV to DVD, and do a far better job than Xilisoft or crap like nidesoft (who happily spam forums without being invited.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. Xilisoft video converter help
    By paul278 in forum Video Conversion
    Last Post: 18th Sep 2011, 05:12
  2. Replies: 7
    Last Post: 13th Aug 2011, 15:19
  3. Xilisoft video converter
    By Vman94 in forum Video Conversion
    Last Post: 12th Jul 2011, 11:35
  4. Replies: 11
    Last Post: 30th Jul 2008, 02:31
  5. Xilisoft video converter help
    By burgkev in forum Video Conversion
    Last Post: 16th Mar 2008, 16:32
