Because new version 2 have "unknown" problems I make some change on version 1_2_1:
New font with outline for OSD, SETUP (must be like in V2 version).
Full Unicode support for ISO+Joliet / USB (Thanks to shoora).
Add for TV Type PAL and Multi, but NTSC is default.
Move few pixels subtitles to left.
Two version with and without volume on Repeat keys.
DVP5990_37_vb6_v1_2_2_volume.rar
http://rapidshare.de/files/41206251/...olume.rar.html
Results 301 to 330 of 949
Thank you for the updated firmware. What does "Full Unicode support for ISO+Joliet" mean?
vb6rocod
about DVP5996K_51_vb6_v2_2.rar
how i sad before, changing FONT1 in this firmware with FONT1 from philips original firmware - change OSD language to russian without any non-russian symbols.
But now there is only russian language in OSD, and if we try to change it to ENG or any other - OSD language don't change - and still be russian. So, it is not critically for us, because we need only russian language, but i tell you about this beacuse it may be a bug. if there is no bug, then all ok.
now with DVP5996K_51_vb6_v2_2.rar with another FONT1 we have russian OSD and rus|eng file names in file browser.
vb6rocod thanks for help!!!
may i ask you some another questions.
what can be file name length in file browser from USB FAT32 in DVP5996K_51_vb6_v2_2. i have 14 chars (but here on that forum i see that lenght is 25 chars). or ours VP5996K_51_vb6_v2_2 not have same fix?
so, count of files list in file browser window now is 4 items. but may be i saw here that it must be more than 4 items. or the same, ours VP5996K_51_vb6_v2_2 not have same fix?[/b]
I am very confuse....
In V_2_2 OSD Language is:
so, no russian language....Do apply a RESET after update?Code:2. No Pic. | OSD Language | 0 0008 FFFF 0273 0000 0011 0000 0004 0000 FFFE83 20AB - ROM:366C 1. Auto | [00] | [00] 041F 0254 0254 0F - ROM:3599 => 2. ENGLISH | [00] | [00] 0279 0254 0254 00 - ROM:3592 3. FRANÇAIS | 0 | [00] 027D 0000 0254 09 - ROM:35A7 4. ESPAÑOL | 0 | [00] 028A 0000 0254 0A - ROM:35AE 5. PORTUGUÊS | [00] | [00] 0288 0254 0254 07 - ROM:35D8
Try to unplug from power for 10 min. and see if still you have russian language.
Original font 1 is different from what I use in v2_2. I need a font with transparent background and with outline. For this I need to make a new font, but I need to "map" char from 257 to 346. For this reason I ask you to fill table with unicode value. Then, I can add russian language to OSD language.Also I need to add new menu in russian language.
About 14 char on USB, that's impossible, you must have 25
And I write, before upgrade SET OSD to English.
Do you test this version?Originally Posted by MidnightWatcher
Unicode support is to show all special characters from your language (not only basic latin alphabet). Of course for US that's not need, but I want to make for other language.
vb6rocod
yes, i reset after update.so, no russian language....Do apply a RESET after update?
but russian language is in firmware. it's "language 9 [08]" from language list. language 9 uses FONT1[00-01] thats why i change FONT1
Russian language in 1. Auto | [00] | [00]
in OSD it seems like - "Auto (RUS)". and all another language from list you post upper. But if i try to select and apply another language (not "Auto (RUS)") its not work. i still have "Auto (RUS)". But its not a problem because we have russian language.
Many people tested and all still have "Auto (RUS)". And all testers set ENG before update and did reset after.so, no russian language....Do apply a RESET after update?
i will test it again on rus and eng file names.About 14 char on USB, that's impossible, you must have 25
yes. and its font dont have russian char. instead there is some symbols, may be it is chars from another language. so because i insert original FONT1 from philips firmwareOriginal font 1 is different from what I use in v2_2.
if you still need it i will do it. i dont do it now because we have RUS in OSD. but if it really wrong and strange tell me please and i will fill table Immediately!!!For this I need to make a new font, but I need to "map" char from 257 to 346. For this reason I ask you to fill table with unicode value.
Also pople reportsabout problem (i don tested it myself) (on original firmware was ok they say)
when try to load DVD+R disk then player shutdown. if DVD-R there was no problem. DVD+RW works too.
OK, I will make v1_2_2 for you. I will "fill" table myself. I hope that in this version, language to be OK.
In file browser, file are displayed OK? (special char). Remember, only for USB, ISO+Joliet (normal burn) not UDF.
your answer for me i guess...Originally Posted by vb6rocod
in file browser, file names and files are displayed OK. (But i change FONT4 on another same-like font(more bright font))
also i can fill table list myself, you do your hard work and i dont want ask you to do it...
it's a pity if be v1_2_2 (higher version is better as usually), but if now another way. But in any case its more better then we have. thanks
For DVP5996K_51
New OSD font:
ini file to use in MTKFontCreator:
http://rapidshare.de/files/41208625/...7_OSD.rar.html
Version v_2_2 with know bug with DVD+.
DVP5996K_51_vb6_v2_2_osd.rar
http://rapidshare.de/files/41208630/...2_osd.rar.html
I change root menu to display correct language
and version 1_2_2:
DVP5996K_51__vb6_v1_2_2.rar
http://rapidshare.de/files/41208634/...1_2_2.rar.html
Check if DVD+ work correct
I hope that I map correct char.
vb6rocod
About 5996K_51
No one work
DVD + - out
Keys "55" don't work
Change Lang at menu disn't
Thank you. If you must Help please. All big Russia for you
[/b]
vb6rocod
i will test all and if its a map problem i will fill table list and post it here
i test DVP5996K_51__vb6_v1_2_2.rar
i tested only with USB. There is ALL OK!!! Menu language changing ENG/RUS now. File browser works with cyrilic file names.
Keys "55" work propertly.
i make a mistake. there is 25 chars from USB device with this firmware. sorry.
i don't see no errors in char table.
vb6rocod many thanks to you! you are genius.
p.s. please understand wright words of LEONard3. he only said thanks not another.
vb6rocod may i ask you about items count in file browser.in file browser windows now 4 file names (files) listed. in next fixes will be more files listed? (file browser window can contain 6 or 7 items(files))
More message like "LEONard3" and I loose my interest....Originally Posted by warplex
I still wait a test with DVR+, I have an "bad feeling".
More files... I try few time ago, and work 90%... still have a bug when return from folder > 4, return is like in case with 4 files. This bug is present (from what I know) in all mod philips firmware (5980K). To make this 100% I need C source (original).
Maybe you have "courage" to test v2_2_OSD.
vb6rocod
he is only say thank you. but it said on very bad english, so because you (and i too while not ask him on russian) not understand his words. he's sorry.
So, how i said higher(yesterday i wrote about v2_2_OSD but copy|paste not that text), v2_2_OSD works fine. Works all without DVD+ (how you said). And there was 1 mistake in char table, wich was corrected by LEONard3.(2 letter look like each other)
DVD+ in v_1_2_2 and all other works fine (like in originall firmware)
Thank you very much!
if any test will find any bug, i will reply here about it.
p.s. vb6rocod, may i ask you about how and with you open firmware to edit char map... For exsample, if phillips will give us new version of firmware (like 5996/51_33) it will be new version without rus. lang. and pathes, and we will need to be asking you to make fixes. so if you can tell how we can modify firmware, we will not disturb you, you already make so hard work for us, and other people.
or we may ask your help again?
Minor change for DVP5996K_51
Fix OSD char "Фф".
A "bigger" font for File Browser.
Change font "Large", now is for cyrillic. Change Medium (new) with Large.
I put in archive ini file to use in MTKFontcreator for OSD font.
DVP5996K_51__vb6_v1_2_2_OSD_FIX.rar
http://rapidshare.de/files/41217760/...D_FIX.rar.html
This is last....
vb6rocod
Thanks for all!!!
Thanks vb6rocod for your excellent work!
I have the philips DVP5992 and was trying to play a ripped DVD off the USB stick. The video works fine. The problem is audio. The files on a burned DVD have AC 5.1 sound, but when played on the philips DVP5992 via the USB 2.0 port it only gives me the option for 2.1 sound. Any one know a way around this problem. I'd prefer to use the USB stick rather than burn DVDs
Also When running VOB files off the USB stick, the player does not recognize them as a movie..meaning there is no way to navigate the menu, like you would on a normal DVD. I just have to skip through it. Any way to solve this problem on USB?
Go read the first post and the FAQ.Originally Posted by rimmi2002
I've tested the last firmware 1_2_2 and i dont know what full unicode means ,because the romanian characters are not recognized and it's not loading any sub files(different names for subtitle and movies), and the meniu is the same with 1_2_1 version ,not like the 2_2.
So I say that the 2_2 version is the best ,(I have maybe 10 dvd+R, so the fact that not recognize this type does not affect me too much).
Good work vb6rocod .
I was wondering if there is something similare for the dvp5140/37 (correct romanian language for .avi movies ).
LA MULTI ANI !
And from me tooOriginally Posted by warplex
change from v1_2_1:
* new font with outline for OSD message, new Setup menu.
* new option for subtitle color. New menu for Background and Outline color. Add color Black and "Transparent".
* move subtitle position few pixels to left.
* add a new menu for vertical position of subtitles, with 16 steps. Special for users with plasma TV and custom zoom ("Zoom1" or "Cine").
* add a new menu for "loaded subtitles", good if movie and subtitles don't have same name.
* Add PAL and Multi to TV Type. NTSC is default.
I make 2 distinct version:
If you use Vobsub subtitle (sub/idx), I make a version without patch "Load org then all", because with this patch only first sub/idx is loaded.
So, if you use this type of subtitles use this version:
DVP5990_37_vb6_v2_3_2.rar (and for West Europe - CP 1252)
http://rapidshare.de/files/41226920/...2_3_2.rar.html
and for East and Central European subtitles (CP 1250)
DVP5990_37_vb6_v2_3_2_CP1250.rar
http://rapidshare.de/files/41226929/...P1250.rar.html
for Greek (CP 1253)
DVP5990_37_vb6_v2_3_2_CP1253.rar
http://rapidshare.de/files/41232989/...P1253.rar.html
for Turkish (CP 1254)
DVP5990_37_vb6_v2_3_2_CP1254.rar
http://rapidshare.de/files/41232994/...P1254.rar.html
Cyrillic (CP 1251) also support Cyrillic in file browser -USB/ISO+Joliet
DVP5990_37_vb6_v2_3_2_CP1251.rar
http://rapidshare.de/files/41232987/...P1251.rar.html
If no, use this (with patch "Load original subtitle,if not found, load all")
DVP5990_37_vb6_v2_3_1.rar (and for West Europe - CP 1252)
http://rapidshare.de/files/41226861/...2_3_1.rar.html
DVP5990_37_vb6_v2_3_1_CP1250.rar
http://rapidshare.de/files/41226911/...P1250.rar.html
for Greek (CP 1253)
DVP5990_37_vb6_v2_3_1_CP1253.rar
http://rapidshare.de/files/41232983/...P1253.rar.html
DVP5990_37_vb6_v2_3_1_CP1254.rar
http://rapidshare.de/files/41232984/...P1254.rar.html
DVP5990_37_vb6_v2_3_1_CP1251.rar
http://rapidshare.de/files/41232979/...P1251.rar.html
Each version is with or without volume on repeat keys.
After update and "Reset", change font, color, and position.
NEWEST VERSION ("vb6_v2_3_1") FIRMWARE FOR PHILIPS DVP5990_37 DVD PLAYER NOW SEEMS OK.Originally Posted by vb6rocod
PRELIMINARY TESTS: Seems *ALL* Is Now Completely OK - DVD+R Problem Now Seems To Be Solved.
After Installing The NEWEST VERSION FIRMWARE (Version "vb6_v2_3_1" [*Without* "Volume" On The "Repeat" And "Repeat A-B" RC Keys] Of The Newly Available "DVP5990_37_vb6_v2_3_1.rar" File Downloaded From http://rapidshare.de/files/41226861/...2_3_1.rar.html ) To Our Philips DVP5990_37 Player And After Performing The Usual "Default Reset" And "Setup Configuration Procedures" (Involving "Component Video," "Progressive Scan Mode," "Digital Coaxial Audio") For Our Present AV System ("Sony KDL-52W3000 TV" & "Yamaha HTR-5790 AV Receiver" & "Philips DVP5990_37 DVD Player"), DVD+R Discs (Verbatim) With MP3 Files And Similar DVD+R (And DVD+RW) Discs With AVI (And Related SRT) Files As Well As Similar DVD+R Discs With NTSC MOVIES And Similar DVD+R Discs With PAL MOVIES Now All Seem To Be Well Recognized By The Philips DVP5990_37 DVD Player And All DVD+R Discs Seem To Play Very, Very Well In The Player.
Usual NTSC Video And PAL Video (As Well As Usual Audio CD) Discs *ALL* Play Very, Very Well Also.
UPDATE - NEWER TESTS:
DVD+R DISCS - *ALL* AVI, MPG, MP4, WMV, DIVX Video (As Well As JPG Picture) Files Played OK.
CD-R DISCS - *ALL* MP3, WMA (As Well As 5.1 DTS) Audio Files Played OK.
USB PORT - *ALL* JPG Picture Files From Digital Camera ("Olympus Stylus 1030 SW") Played OK.
THANKS vb6rocod For *ALL* The Newest FirmWare Improvements!
(NOTE: These Preliminary Tests Are Similar To Our Earlier Ones Regarding The Older Version "vb6_v_2_2," Posted "Dec 23, 2008 12:56" - http://forum.videohelp.com/topic355675-270.html#1920859 And The Older Version "vb6_v2," Posted "Nov 25, 2008 17:06" - http://forum.videohelp.com/topic355675-180.html#1911417 .)
Thanks for testing u4s.
[s:d546151bcc]vb6rocod can you give me a change log from v1. So I can add a description to front page.[/s:d546151bcc]Thanks for all your hard work.
Update for DVP5996K_51 must be tested! (update from 1_2_2) Check DVR+
* Vertical position for subtitles (16 steps)
* New color option for subtitles. Add option for Background and Outline color. Add Black and "Transparent" color.
* Add new menu for "Load matching subtitles, if not found, load all (max. 10)".
Two version, with and without patch "Load ORG Then All".
For users hwo use Vobsub subtitles (and have more than one movie/Vosub subtitles - sub/idx in a folder), use version Without Load ORG. For rest, use version With Load ORG.
DVP5996K_51_vb6_v2_3.rar
http://rapidshare.de/files/41233957/..._v2_3.rar.html
I have 5992/37 player and was having trouble with "KOREAN" subtitle.
I installed DVP5990_37_vb6_v2_3_2.rar firmware now,
and tried smi, srt, and vobsub(idx/sub) subtitles, but non of them worked.
smi and srt gave broken characters, and vobsub gave nothing...(I've tried
different options for bitmap color settings).
Today, I tried AVIAddXSubs with not much expectations.
However it worked! Interestingly, it displayed KOREAN subtitle with
different font style which I specified with AVIAddXSubs.
(when I played the same file on my computer, it gives out designated font style)
so, I am happy, but wondering what's going on...
just looking at the firmware, it doesn't look like have full KOREAN character set
with it, then how come it can display korean font with different style?
well...I think there was some confusion...
because there were a couple of differnent kinds of subtitles on my computer,
when I use AVIAddXSub.
anyway, using AVIAddXSub can be a way to solve "KOREAN" font problem.
For Vobsub is VERY IMPORTANT to select PAL for movie with 25fps, OR NTSC for 23,976 or 29,97fpsOriginally Posted by beatty
I have a similar problem using DVI->HDMI into my Hitachi TV. Composite works fine but the digital out gives screwy results. Upon powering on the 5992 the screen is shifted halfway to the left in 1080i mode (with differing screen size/position errors depending on resolution). The menu and DVDs also are half a screen to the left, but when I play anything from the USB port, the problem fixes itself, and then the menu and DVDs play fine.Originally Posted by lucky123
After digging online and talking with Hitachi tech support, there is no record of this happening with the player or with the TV. I have never tried the original 5992 firmware as the first thing I did upon purchase was update it with vb6's. Do you have this problem regardless of the firmware you have installed? I wonder if anyone else can shed some light on this bug.
Hi
first many thanks to @vb6rocod for the work you have done for us all, it is very much appreciated & one of the reasons I bought this particular player.
Please could you consider the following things if you have time for more development.
1). When displaying jpg files the player seems to load the picture, then after it is loaded the transition to display the picture is very long. Could this transition effect be removed please? When the picture starts to be displayed, pressing <forward> shows the picture instantly, but the drawback with this is that the next picture is then displayed automatically. I think the best behaviour might be that the next picture is always loaded but not displayed until <forward> is pressed, at which time it could be displayed instantly.
2). The file list only contains 4 items although it looks as if more could be displayed in the space, more files being displayed would make navigation easier.
3). When displaying lists (like the file list) could the cursor continue to move if the key is held in please? Instead of the current behaviour that means the key has to be pressed repeatedly.
I have the 5990/12 I am posting in this thread because it seems to be the most current, I hope this is ok
Thanks,
5990 Firmware download?
By marioval in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Nov 2010, 06:44 -
[Release] Philips 5990/12 modded firmware by vb6
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 138Last Post: 28th Sep 2010, 18:12 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 16:06 -
5990/12 firmware instruction
By Yugos in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Dec 2009, 18:14 -
Phillips 5990 - How to revert back to original firmware
By user111 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Feb 2009, 19:31
