VideoHelp.com Forum
    Got an odd problem with the above DVD recorder....
    Have just finalised two discs in the machine which play fine in this recorder. However, when I try to play them in my Pioneer DVR-420H it just says "Cannot read disc" All other discs loaded into the Pioneer play fine and I have never had a problem playing discs in it before.
    Tried the discs in the cheap H&B DVD player we have and they play fine.
    I'm using maxell discs so I'm confident that the media I've recorded onto is okay. Have I somehow set the Philips recorder up wrong? Has anyone else come across this problem?
    TIA
    Sorry, forgot to say that the DVR3480 is a Philips machine.....
  3. Have you changed disc media recently from + to - or R to rw? I think they are handled differently..
    The electronic components of the power part adopted a lot of Rubycons.
    The Pioneer is a -R/RW machine. Maybe you usede +R/RW?
    Will try another disc but the maxell ones that I'm using at the moment state DVR-R (Maybe I have a faulty pack and they are DVD+R labelled as DVD-R?) Will let you know what happens......
  1. Replies: 4
    Last Post: 28th Jul 2008, 21:57
  2. video card problem causing watching movies problem?
    By vipertongn in forum Computer
    Last Post: 11th Jun 2008, 11:39
  3. Recommended Disks for Philips DVDR3480 Recorder?
    By Kargo in forum DVD & Blu-ray Recorders
    Last Post: 12th May 2008, 15:16
  4. Philips DVDR3480
    By 557953 in forum DVD & Blu-ray Recorders
    Last Post: 27th Sep 2007, 17:22
  5. Replies: 5
    Last Post: 16th Jun 2007, 03:03
