I was looking to convert an FLV from vimeo into mpeg2 for a home DVD project. [I'm putting together a birthday DVD for the grandparents with quips from my daughters, and needed fireworks, and vimeo had better samples to supplement what my special effects department could create; in case you wanted context.]
I couldn't find much about Vimeo specifically (most posts are related to putting stuff on vimeo, not taking stuff off), but eventually found SUPER. While the program looks great, I was scared by the size (anything that big sounds like bloat-ware), but it seems to run fairly well. SUPER played the files well (better than the flash plugin to IE played them--my laptop is several years old), but didn't convert. Selected FFmpeg, and putting attributes as close to DVD as reasonable, it would only convert a few seconds of video, then go to some god-awful compression blocks of random weird green colors--imagine seeing the 4 seconds of aurara borealis at 60 bps. I even tried the DirectShow decode, it's still craps out like that.
Looking further, I tried WinFF, the graphical front end to FFmpeg. It worked great with the vimeo files, and created exactly what I needed. Even the options of going 16:9 or 4:3 are helpful. I love the program, being able to see what it's doing running the command line. I highly recommend.
So, my post is to share my experience, but also ask if there is anything I might have done wrong with SUPER? Am I best in just going forward with WinFF?
Thanks!
Tim
Results 1 to 1 of 1
Thread: Vimeo Conversion
Question from beginner. Trying to convert .vob to play on Vimeo
By thegreatdanton in forum Newbie / General discussionsReplies: 2Last Post: 11th Mar 2011, 20:26 -
no image from vimeo
By butterflies in forum Video StreamingReplies: 1Last Post: 22nd Dec 2009, 03:12 -
Processing power for H.264... YoutubeHD vs Vimeo vs ???
By The111 in forum Newbie / General discussionsReplies: 39Last Post: 1st Jul 2009, 06:10 -
Problems with Vimeo Encoding
By Xenon77 in forum Video StreamingReplies: 2Last Post: 28th Apr 2009, 12:04 -
vimeo uploading help
By pantsdavies in forum Video StreamingReplies: 3Last Post: 22nd Sep 2008, 18:34
