Hi ppl,
I have SR10 and trying to create DVD's. As with multiple others, I have used PMB succesfully ( only once) to create DVD's and now getting the error msg at 50%. I have read other threads extensivley including some of your answers.
What are my real options other than using PMB?
1) Can I use Adobe premier or Pinnacle 11 without any hassles.
2) If I use streamclip to re encode to some format for Nero to accept which is the best fromat that will not compromise the quality.
3) Also when I import files to my computes you very well know that a handycam is recognised as external source. But a single file is recognised as m2ts and another 2 formats. Although m2ts is the main file as it is in mb the other 2 files have different extensions and are in kb. Do I need to convert all 3 of them?
4) Also which is the best software once you have converted into a required format to add music and headings?
I have tried using Elecard, but found it difficult to follow. Ulead11 is a bit difficult to understand and its a bit beyond my knowledge. Someone please help me. If there is any link that gives a step by step tutorial for any of the above, or for another software then that would be most welcome.
Many thanks,
Results 1 to 1 of 1
mp4 to flv file I only get sound through the web browser but no picture?
By robbg in forum ffmpegX bugs and suggestionsReplies: 2Last Post: 21st Mar 2010, 11:04 -
How can I get videos from Picture Motion browser to Windows Movie maker?
By AuraTodd in forum Video ConversionReplies: 6Last Post: 13th Mar 2010, 05:29 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
LCD Motion Blur - Options/Alternatives
By JohnnyMalaria in forum DVB / HDTVReplies: 12Last Post: 13th Dec 2009, 11:20 -
Picture Motion Browser for HDV
By manosaa2 in forum Software PlayingReplies: 8Last Post: 24th Jun 2009, 23:16
