I just switched from PC to Mac and is a little disoriented. I collect music videos and use these to make quizes among other things. For this I need to be able to cut (trim as QT-pro calls it) parts of the file but with mpg there is no trimming option. The start and stop blocks represented in the movie timeline (bottom of the screen) are simply not there.
I have the mpeg-2 plug-in installed as well.
Is there anyone who have a solution for this? Either in QT-pro or another program that I could use instead?
Thank you
/Kim
Thread: cant trim/cut mpg in QT-pro
MPEG Streamclip will do the job.
Thank you kindly for the fast answer. Works perfect.
hat of for Ffooky
/K
How to trim / cut a .mov file?
By AshleyQuick in forum EditingReplies: 3Last Post: 4th Oct 2011, 16:46 -
HELP - Need software for mac that can trim/cut clips without quality loss
By someone04 in forum MacReplies: 6Last Post: 3rd Mar 2011, 18:06 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Final Cut Pro imports .MPG's with no audio.
By Benhermies in forum MacReplies: 2Last Post: 20th Sep 2009, 16:09 -
How to cut/trim HD-MPEG2 without encoding?
By edong in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 27th May 2007, 17:50
Statistics
Newest guides
Latest tool updates
New media comments
