VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 50 of 50
  1. Never mind, I got it. I am dumb beyond belief!
  2. BuskerAlley.com zoobie's Avatar
    I think the pseudo streaming (where video displays while downloading) is encoder specific...
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
    Nope. It's just some info in the mp4 header(so called hinting). If it doesn't start stream automatically you can easily fix it using mp4box, mp4box -hint videofile.mp4 .
    Captain Satellite: Just put your code between [code]code[/code] and it should display.
  4. BuskerAlley.com zoobie's Avatar
    Thanks man...
    I just read to use -isma for mp4box
    Try the easy to use GUI http://www.datagoround.com/lab/
    It's handled everything I've thrown at it unlike the others...
  5. BuskerAlley.com zoobie's Avatar
    Actually, Xvid4PSP comes with mp4box...that's why it progressively streamed...Avidemux not so or at least I didn't see a fast-start option...don't know about StaxRip & Ripbot264
    Also noteworthy is that moving the metadata to the front seems to be mp4 specific...doesn't work on mov, wmv, flv...
  6. Baldrick, thanks from a forum newbie for this guide. It works great! Kudos.
    Is there a way to place an opening image on the player to avoid having visitors see an initial black screen?
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep, just add the "&=image.jpg" to the flashvars like
    s1.addParam('flashvars','file=video.mp4&stretching=fill&image=screenshot.jpg');
    Thanks for that tip. Much easier than using Flash MX.
    I most do something very very wrong here.
    I have create a movie (slideshow) with sound in vegas.
    I create a HD movie (m2t) and I open Xvid4PSP and you the guide.
    I like to have big movie and good quality so I have a bitrate of 1500 so my movie that is 1280x592 is a little over 50 mb in mp4.
    I can play it local and it show very very nice.
    I upload it with the flash but nothing happend, the flash just loading and loading.
    I have try with mp4box, and I have try with Yamb (with mp4box) and I have try with MP4 faststart and nothing change.
    I did try to upload the movie that have been create in this guide and it start play instant so my webserver can stream a mp4 file.
    I have search everywhere but never find any idea that work.
    I have no idea what more I can do?
  11. My video and audio are out of sync after encoding. What would cause this? I followed the guide as close as possible. Thanks for any help.
    This guide worked perfectly for me. Thank you so much!
    Hello,
    when I click to get the player.swf, I get that horrible and annoying page "http://jeroenwijering.com/?abd946cf35380c615c4d9a37e627d2f8=325467165&6fa970d50480e816942b6fab7c4e7a23=506683626&5f17a83ba43604eb3d1c06f73d82e119=63389980066850793 6"
    and I am at a loss.
    Please, where to get that player thing without ridiculous ads?
    Francois
  14. Originally Posted by Francois43
    Hello,
    and I am at a loss.
    Francois
    you have to buy it now. the paid version has no ads.
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    You can try another flash player like flowplayer, http://flowplayer.org/download/index.html
    I was wondering if I could choose AAC-LC ABR instead of the recommended AAC-HE CBR or will that screw with the 'streaming' settings of the mp4 off a webpage?
    Did you actually try it through the flash player on a webpage, because mine is kinda out of sync on my computer (with VLC, WMP with FFmpeg, and quicktime) but when I play it with a flash player off a webpage it plays in sync. Strange.
    BTW- Here's a free flash player that allows commercial use! Hard to find. A bit different then the other solutions. I use the iframe method for multiple videos on a single page.
    http://www.video-flash.de/flv-flash-...-video-player/
  18. Member
    I got the video to play great from my site. Problem is, it only plays the first 50 seconds then stops. I see the bar at the botom fully loaded so it's not a buffering problem though it acts like one. I even restarted my compter but it still stops after exactly 50 seconds. I am using the JW Flv player. Could this be the problem?
    I can see everything else, but not the code. Help!
    Just noticed it's fixed thank you, thank you.
  1. How to make the audio louder in an H264/AAC video
    By rumplestiltskin in forum Mac
    Last Post: 29th Jun 2011, 21:17
  2. High quality video in Flash ads.
    By x2x3x2 in forum Newbie / General discussions
    Last Post: 5th Jun 2011, 12:48
  3. Replies: 8
    Last Post: 5th Feb 2011, 11:39
  4. converting video to h264(mp4) for flash player streaming
    By ricardouk in forum Video Conversion
    Last Post: 1st Nov 2007, 13:58
  5. youtube FLV video with h264 (x264) and/or aac (mp4) audio
    By wiseant in forum Video Conversion
    Last Post: 26th Oct 2007, 16:49
