Hi Everyone, my apologies if this is in the wrong forum. I could not decide between this one and the "streaming" forum.
I have 2 MiniDV cameras which I use to shoot videos for my students. Up until now, I have used the 2 cameras, and at the same time recorded a direct feed from my guitar and a lapel mic into my computer DAW (Sonar version 5.2).
I use Vegas 8 to import the 2 video streams and my mixed audio stream (.wav) from Sonar and then I manually line everything up and edit to my liking.
The system works, but is very tedious. Ideally I would love to be able to capture from my miniDV cams directly to the computer and also capture the audio from my audio interface (a presonus 8 channel firewire interface.) That way, everything would be lined up to start with, and I would not have to wait for the dumping process from the camcorders to the computer.
As far as I can tell, Vegas 8 (platinum) is not capable of capturing everything at once. Is there any software out there that would allow me to do this?
My cameras are cheap, a canon ZR900 and a ZR800. But they do the job as I've done it up until now.
Even if I could not capture both cameras at once, at least capturing one camera and the audio stream simultaneously would be good.
Thanks for any advice or suggestions you may have.
Results 1 to 1 of 1
Audio troubles, with firewire transfer from miniDV cam
By TheBigQuestion in forum AudioReplies: 29Last Post: 29th Sep 2011, 03:39 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum CapturingReplies: 14Last Post: 4th Aug 2011, 06:36 -
Stream & Capture Simultaneously?
By GuidingLight in forum Video StreamingReplies: 1Last Post: 19th Jul 2011, 16:15 -
Some questions about a MiniDV cam
By ermi in forum Camcorders (DV/HDV/AVCHD)Replies: 14Last Post: 9th Aug 2008, 14:46 -
Sony Vegas Capturing Outside Audio instead of MiniDV Audio
By RKelly in forum CapturingReplies: 3Last Post: 29th May 2008, 08:22
