Hey!
I want to encode a movie with the subs "on it".
To do this i'm using the TextSub script in my .avs file like this:
The problem is that after the program finishes encoding, the subs are not big enough.Code:AviSource("D:\movie.avi") TextSub("D:\subs.srt")
is there any script that can enlarge the subs? How can I do it through a script in my .avs file?
Thread: TextSub in Avisynth.
ok. I converted the format to ssa so I can adjust the properties.
Thanks anyway.
I also convert to SSA as it allows much more control over the look and positioning of the subs.
I usually use Subtitle Workshop to do this.
Then I use TextSub to "burn 'em in" to the video.
Only problem is if the video is 16x9 anamorphic widescreen the subs can look short and fat when it gets "stretched out" so if that is the case try to pick a font that is tall and slender ... then it will look more "normal" afterwards LOL
Arial Narrow seems to work wellOriginally Posted by FulciLives
TextSub horror!
By YiuKorochko in forum SubtitleReplies: 2Last Post: 1st Aug 2011, 16:38 -
textsub incompatible with avisynth 2.5?
By icieling in forum DVD RippingReplies: 1Last Post: 1st Aug 2011, 15:56 -
VDub + TextSub + multipass problem
By Keeyu in forum SubtitleReplies: 3Last Post: 14th Jan 2011, 09:11 -
Font problem with TextSub 2.23
By Keeyu in forum EditingReplies: 0Last Post: 8th Jan 2011, 20:42 -
Cn't get the textsub / subtext in VirualDubMOD
By download in forum SubtitleReplies: 6Last Post: 18th Jun 2007, 19:22
Statistics
Newest guides
Latest tool updates
New media comments
