VideoHelp.com Forum
    My friend is the only user as administrator of his PC with Windows XP. He could not install Adobe flash player properly so he could not play youtube videos. Adobe showed (many times) that it installed successfully but Youtube and other site still prompt that he is using older version of adobe. Pentium 4 2.4 Ghz, 248 MB RAM. Anti-virus and Spybot S & D turn up nothing. Thanks for the help.
  2. VH Wanderer Ai Haibara's Avatar
    Which browser is he using? This can also happen if you have Javascript turned off. Also, which version of Shockwave/Adobe Flash did he install?
    Tried downloading and using their "uninstaller" 1st ?
  4. This may not answer this specific problem but you really, really need more RAM in that PC. It could be causing adobe to fail, though I would completely uninstall the old versions as suggested.
    Definitely add more RAM.
    Thanks, guys. Tried everything including installation of two files in the Windows Resource Kits. But after five tries with Firefox, by accident, if finally installed. Don't know how it happened. Internet Explorer still won't cooperate. Now I am thinking corrupted registry.
    I had the same problem. The Adobe Flash player web site has a fix for this problem.
  1. Administrator Privilege to Run VCDEasy
    By asifmcp in forum VCDEasy General
    Last Post: 8th Jan 2011, 04:48
  2. login as administrator W7?
    By neworldman in forum Computer
    Last Post: 18th Mar 2010, 10:30
  3. How to log in as administrator in Windows 7
    By jyeh74 in forum Computer
    Last Post: 8th Feb 2010, 00:58
  4. Network Administrator Ratio
    By oz_surfer in forum Computer
    Last Post: 23rd Sep 2008, 10:16
  5. Replies: 4
    Last Post: 3rd Jul 2008, 13:18
