OK, I came here in the past & was referred to a brand & model of DVD burner to get & was steered in the right direction, the burner lasted a long time & did many many burns.
I again come here to see if the good folks here can recommend me a good DVD burner to get these days?
Thanks in advance,
dudeman316
Results 1 to 12 of 12
Father knows best.
You can't go wrong with a Pioneer. The latest model is the Pioneer 116.
shopping I go, thanks SCDVD, you know a good place to get them & will they burn DL discs?
Father knows best.
http://www.newegg.com/
They do a great job with DL
what about the NEC ND-3520A, I had previously owned a NEC, are the Pioneer better?
Father knows best.
I don't have any recent experience with NEC. Many say they used to be better. NEC no longer makes their own burners.
ok that makes me want to stay away from them more.
Father knows best.
Another vote for Pioneer. Mine works flawlessly.
"Quality is cool, but don't forget... Content is King!"
I have had 4 pioneers in the past 5-6 years. All 4 are still burning strong in various PC's. I would get a Pioneer from New Egg...
this look like the right one:
http://www.newegg.com/Product/Produc...82E16827129024Father knows best.
That's the IDE Version. The Sata Version is a buck more. Just depends on which one you need...
If you're gonna consider getting any SATA dvd burner make sure your motherboard will be compatible with it. Not all motherboard sata chipset controllers will work correctly with sata dvd burners. When sata was first created it was made for only sata hard drives and not for optical drives. If your mobo has intel chipset ich7,8, or 9 the drive will work correctly. If your mobo has nvidia chipset then you'll need to use the latest drivers from the nvidia website and not from the mobo manufacturer. Mobo's with via chipset will not work with sata dvd burners, you'll have to purchase a sata pci controller card that uses the silicon image chipset 3112, 3114 or 3514. Also raid will have to be disabled in the mobo bios in order for a sata dvd burner to work correctly.
Would Appreciate Recommendation for Reliable DVD+RW
By Novice20 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jan 2012, 22:12 -
Need dvd-r recommendation
By mysts in forum DVD RippingReplies: 2Last Post: 30th Dec 2008, 23:58 -
VHS to DVD Recommendation
By Prior in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Aug 2008, 20:01 -
dvd player recommendation
By bagrol1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 21:25 -
DVD Player recommendation
By tomchook in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2007, 09:01
