Ok, so I got all the files, located them and put in my password, I hit install and it gives me this:
I don't know what to make of it, help would be greatly appreciated. I'm running OSX 10.5.4 on a 2.4GHz 17" MacBook Pro.Code:##sh: -c: line 0: unexpected EOF while looking for matching `'' sh: -c: line 1: syntax error: unexpected end of file
This error seems related to an apostrophe character, where there shouldn't be one.
Do you have such a character in a disk name, folder name, or even in your password?
Yeah, I have one in my password, I'll change that and try again.
Changed it and it worked, thanks for the help!
If you're trying to convert a RealMedia source file to something iTunes/iPod/iPhone/AppleTV compatible, then it won't work in one conversion. RealMedia files can only be converted if mplayer is used for decoding, like with a mencoder preset, because reallib is an mplayer plug-in.Originally Posted by Lexodus
iPod/iPhone presets use the ffmpeg engine (not mencoder), and doesn't use mplayer for decoding.
iTunes video files need special information in the file that have to be added by the encoder. The iPod/iPhone presets do this. It also has some video requirements (e.g. AVC level 3.0) that mencoder can't provide. The blank screen probably means that the video is not understood by iTunes.Originally Posted by Lexodus
To bring a converted RM file into iTunes using ffmpegX, you may need two conversions: (1) Convert the RM file to something that the ffmpeg presets can work with, using a mencoder preset. (2) Convert the previous output to something iTunes likes, using an iPod/iPhone preset.
Installation of ffmpegX on os X.6 : error message
By Gruntosaure in forum ffmpegX general discussionReplies: 5Last Post: 22nd Dec 2010, 18:54 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
ffmpegX won't convert files due to "syntax error near unexpected token"
By JayEm in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2010, 17:26 -
ffmpegx Error Message.
By Bunky in forum MacReplies: 1Last Post: 25th Oct 2009, 08:38 -
ffmpegX > what means error message "DIV16_KEY"?
By infopartner in forum ffmpegX general discussionReplies: 1Last Post: 29th Jan 2008, 15:09
