Ok ran out of room on the title
Long story short I just formatted my PC and now all my video encodes have a looping problem (will play once but not loop). The seekbar will either jump from end to start or seem to just jitter near the end . While the video does in fact get a image of the first frame but it does not do anything else (expect maybe jitter a little).
All these encodes were xvid.
In addition if I open up ANY video (including one that is bugging out) then open up another MPC and put the vid in that also, that vid will work fine and loop fine (yea, weird).
VB seemed to once say something about an infinite loop but it might have been about something else... since then it hasnt popped up.
Some of the codecs I installed: CCCP, Xvid, Divx, qlite, realalt, mkvinst, 3ivx.
NOTE: So far it seems only my encodes are doing this.
Tip: If you are going to comment on a reply, make sure he aint a mod.... :/
Looping or returning to the start is a function of the player, not the file. In MPC go to View -> Options -> Playback and set Repeat Forever, Play [n] Times, or Rewind When Done Playing.
bump
well whats the name of the tool that tells you what codecs XX video is using? Maybe I can take a look into that...
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
Vid Caps
By moonshadow in forum Video StreamingReplies: 5Last Post: 22nd Feb 2012, 09:31 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum CapturingReplies: 2Last Post: 22nd Dec 2011, 10:50 -
A Question On How To Calculate Frame Size When Resizing Vid for DVD
By hydrophonicaudio in forum Newbie / General discussionsReplies: 13Last Post: 21st Feb 2011, 07:53 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 11:48
