VideoHelp.com Forum
    I run a video-sharing site and I want to automate the process of uploading content to my site. Is there a command-line tool I can use which will take ONE input avi, and generate an x second sample of it. I have been playing around with VirtualDub scripting and specifically the VirtualDub.video.SetRange function but what works for one video, won't work with another.
    I'm stumped!
    i have tried this command for cutting some avi part:
    ffmpeg -ss 180 -t 60 -y -vcodec copy -acodec copy -i long_input_file.avi short_output_file.avi
    but ff show me this error message:
    [NULL @ 015781B0]Invalid and inefficient vfw-avi packed B frames detected
    Assertion failed: st2->time_base.den == ast2->rate, file libavformat/avidec.c, line 1029
    This application has requested the Runtime to terminate it in an unusual way.
    Please contact the application's support team for more information.
    pls help me
  4. Member Soopafresh's Avatar
    Try a different version of FFMPEG
    http://tirnanog.fate.jp/mirror/ffmpeg/
    If that doesn't work, try to unpack the bitstream on the source AVI file
    http://www.moitah.net/download/lates...ModifierCL.zip
    Batch processor for above utility
    http://www.burrrn.net/download/Packe...%20Remover.zip
    oh god, different version work successfully.
    very very very much thx man!!!
    ...u save me too much works.
    i have one little problem with this:
    ss=180 = start frame is 4500, but cutting avi video is possible only in keyframes, that means really start frame is for example 4399, but audio is always cutted "in frame" 4500, not 4399. after this is audio in output avi desynced.
    exist any way to fixed this ffmpeg command?
  7. VH Veteran jimmalenko's Avatar
    Vdub possibly uses frame numbers, and not timecodes. This would explain why you cannot get a consistent x second preview, without knowing the original frame rate.
    If in doubt, Google it.
  1. CrossPlatform command line tool to multiplex avi files?
    By Selur in forum Newbie / General discussions
    Last Post: 23rd Mar 2012, 15:29
  2. Replies: 2
    Last Post: 1st Jan 2010, 02:19
  3. Command line tool to make x264 mkv samples
    By lime- in forum Editing
    Last Post: 1st Nov 2008, 16:58
  4. Command line text overlay tool
    By lmundy in forum Linux
    Last Post: 13th Jul 2008, 13:58
  5. Command-Line Tool to Join Videos?
    By RobDude in forum Editing
    Last Post: 4th Jul 2007, 12:53
