Hi. I downloaded the trial version of VEgas Video 3.0 and I had a question about the effects that you can apply to the video. When you go to select an effect, it takes you to that screen where you can edit the effect whatever way you want. My question is how can you modify the effect so that it isn't in the whole clip? Whenever I apply an effect, it stays on the whole clip. I only want it to be at a certain part of it. Any help will be appreciated.
Thanks :P
Mike
Thread: Vegas Video 3.0 Effect question
Hi Mike,
Open Vegas, load your source AVI file into timeline. Select video track. Then click with your mouse where you want to insert your FX. Then click Edit on the menu bar and then click Split. Now click with your mouse where you want your FX to stop. Click Edit on the menu bar and click Split. Then drag and drop your FX into that split part of your video track.
Regards.
Sony Vegas how to make this effect?
By wingfan in forum EditingReplies: 0Last Post: 16th Jun 2011, 11:53 -
Which video editor for this effect? (a noob question)
By thea in forum EditingReplies: 5Last Post: 26th Apr 2010, 07:51 -
VHS effect Vegas
By Abas-Avara in forum EditingReplies: 8Last Post: 30th Oct 2009, 16:47 -
help with sony vegas effect
By cadogan in forum EditingReplies: 0Last Post: 21st Sep 2009, 16:59 -
Snapshot effect in Sony Vegas?
By mashimiriam in forum EditingReplies: 1Last Post: 28th Aug 2008, 17:57
Statistics
Newest guides
Latest tool updates
New media comments
