VideoHelp.com Forum
    I use the latest AVI2ISO version to transfer an avi to DVD. The image is very good with 3 passes with CCE, but the sound is completely gone. The packages included some kind of AC3 codec, but the sound is gone anyway. Can someone tell me what’s wrong?
    Johansson
    For some reason it was unable to extract audio. If you can play them in WMP, use DirectShowSource method
    If AVISource fails, DS is an alternative, the audio processes are different
    I upgraded the sound from 109 kbit to 192 kbit. I didn't have this problem when I used an older version.
    From the older versions to the new one it was only changed region conversions for MKV, some other bugs fixed, and new features. The core audio processes weren't changed
    It must be another problem with that particular source. Try with other source
    DirectShowSource uses other processes, is an alternative to AVISource
    You should also use the forum of that program
  1. AVI2ISO help
    By Loader09 in forum Authoring (DVD)
    Last Post: 22nd Nov 2009, 04:23
  2. no sound problem
    By bountylord in forum Video Conversion
    Last Post: 26th Apr 2008, 18:37
  3. AVI2ISO
    By marioval in forum Authoring (DVD)
    Last Post: 5th Feb 2008, 09:39
  4. problem with my HP sound
    By arabian in forum Computer
    Last Post: 27th Dec 2007, 03:51
  5. Problem with sound
    By jarko in forum Newbie / General discussions
    Last Post: 11th Aug 2007, 20:22
