Hey, I tried the hack below that was supposed to work but didn't:
[url=http://www.videohelp.com/dvdhacks/samsung-dvd-vr330-eu-version/7107
[quote]Thanks Andrey - The same works on the DVD-VR350
(ps - it also worked for my old Samsung SV-DVD1E - where the hack was posted by tonjac, August 08 2001
Rember code for set region is different depending on what region your player is *currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
As I had a Region 5 player I hit Menu the 53814 followed by 9
Player now happily player DVDs from the Uk etc
)[/quote]
The link to the hack:http://www.videohelp.com/dvdhacks/sa...u-version/7107
Anyone have a region free hack that works? My Samsung dvd-vr350 was bought yesterday.
Thread: Samsung dvd-vr350 hack needed
Hardware changes by the manufacturer sometimes break hacks that used to work. Perhaps this has happened to you.
Probably.
After re-reading this, I realized that you are a new member and I should not make assumptions that you did this correctly. You will need to do:
Menu 38767 9
to change your region. If you followed Andrey's instructions to the letter, which are for changing a region 5 player, that will not work. If you followed the correct instructions than my suggestion in my original reply is probably the problem.
I did use 38767, I'm not stupid.
I didn't say you were stupid, but you'd be surprised how many new members do make mistakes. However, if you are that easily offended, then you're not really likely to get much out of the forums here.
two things:
1 - the remote must be switched such that it will not control the TV but the DVD
2 -I changed to region free, from 2 (Europe), but the NTSC (US) movies - region 1 - although playable but Black and White. Cannot get it in color.
new hack for samsung DVD-P181 needed
By indigogirl1200 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 9th Nov 2008, 20:58 -
Samsung VR350 DVD Recorder Will Not Play Recorded Discs On Computer
By bmck in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Feb 2008, 16:01 -
Samsung Region 1 DVD-V5500 hack needed
By Palaver in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Jan 2006, 13:49 -
Region hack needed for SAMSUNG DVD-S221 please!
By LiNUXG33K in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th Oct 2002, 19:10 -
Hack for Samsung DVD/TV needed
By Bezcom in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Oct 2002, 10:27
)[/quote]
