Thread: BD Codec?
  1. I apologize in advance if this has been asked before, or this is the wrong section.
    I created a BD MPEG with PCM audio using Ulead Videostudio, but when I play it the audio doesn't play at all. I also tried creating an HDDVD MPEG with PCM audio, but when I tried to play it the audio is very scratchy and the video studders a bit. This is using Windows Mediaplayer. I also noticed I couldn't convert either of these MPEGs using TMPGEnc, it just gives an unrecognizable file error.
    Is some sort of codec or different type of player required to play these MPEGs? They are 1920x1080 60i with PCM audio. I have a Phenom 9750, so I assume it's not a speed issue.
  2. Just to clarify, Ulead Videostudio exports an MPEG-4 suitable for use on a BD or HDDVD disc (1920x1080 60i PCM) but the result is not (yet) in BD format. But for some reason, I can't play the MPEG-4...cleanly anyway. Do I need a codec to play the MPEG-4 properly with Mediaplayer or why would it not play correctly?
  3. you need a really fast computer to play hd mpeg-4.
  4. Strangely enough, the video plays ok, but the audio is silent or scratchy. Is LPCM non-standard?
  5. lpcm is in the hd&br specs, it shouldn't be any problem.
  1. Replies: 13
    Last Post: 4th Nov 2008, 09:41
  2. Surveillance Camera Codec -- Super Realtime Video Codec, where can I get it
    By BenjaminT in forum Newbie / General discussions
    Last Post: 19th Feb 2007, 15:49
  3. Replies: 9
    Last Post: 11th Sep 2006, 02:17
  4. Replies: 1
    Last Post: 8th Jul 2006, 22:34
  5. Gordon knot codec pack - codec problem
    By Pipzter in forum Software Playing
    Last Post: 1st Jan 2005, 20:20
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
