VideoHelp.com Forum
    Is it possible to connect my Dell D630 laptop with only a vga connection to my older television which only has the RCA inputs? I bought a cable ( http://cgi.ebay.com/VGA-to-TV-Conver...QQcmdZViewItem ) but it does not seem to work.. even though my video card does have the capability. I went into the display options but the card does not detect a monitor attached..
    any help?
    anyone?
  3. Member edDV's Avatar
    No won't work. Unless this is an option provided from the laptop manufacturer. This has been covered numerous times. Use search.
    Search "laptop VGA S-Video"
    http://www.kiva.org/about
  4. Member edDV's Avatar
    Your Dell Laitude supports the D/Port for docking. The video goes through the docking connector.
    http://www.dell.com/downloads/us/pro...ly_docking.pdf
    http://images.google.com/imgres?imgu...%3Den%26sa%3DN
    If it doesn't work with just the cable alone you can always use a VGA to composite converter box to convert the signal into your TV. I use one from my DVI ports on my desktop as I don't have an HDTV to plug into. I picked a box called Grand Ultimate Vision up in Hong Kong for around £15 but you can get similar ones on Ebay for a fairly cheap price. Obviously try the cable out as much as possible first but if not then this is a pretty decent alternative, hope this helps.
  6. Member edDV's Avatar
    Modern laptop makers have mostly standardized on the DIN "TV port" with 4 to 9 pins for analog video connection. The VGA connector is rarely if ever used to pass composite/S-Video.
    Pins 1-4 are always S-Video on the "TV Port" pins 5-9 functions vary by display chip manufacter. Modern NVidia chipsets pass composite, S-Video and analog component (SD and HD) over the TV Port.
  1. Problems connecting a laptop through the SVideo port to a Display VGA input
    By jeproca in forum Newbie / General discussions
    Last Post: 4th Nov 2010, 09:31
  2. COnnecting Sony Vaio Laptop to Pioneer TV with VGA/RGB cables
    By togu68 in forum Media Center PC / MediaCenters
    Last Post: 25th Aug 2009, 20:47
  3. Connecting laptop VGA to TV S-video
    By tezarin in forum Newbie / General discussions
    Last Post: 2nd Apr 2009, 16:09
  4. Connecting PC and TV by VGA to S-Video
    By CoDe-D in forum Newbie / General discussions
    Last Post: 23rd Oct 2008, 20:35
  5. s video or vga to television
    By thinger62 in forum Newbie / General discussions
    Last Post: 17th Dec 2007, 07:57
