VideoHelp.com Forum
  1. AGAINST IDLE SIT nwo's Avatar
    i just updated from 7 to 8 and can't seem to find AC3 in render as, 7 used to have to make option AC3 files, or have Sony just removed that option from Vegas as i see .AA3 file does 5.1 too.
  2. vegas pro 8 makes ac3 files of any flavor you wish. give it a wav file and choose render as dolby digital ac-3 pro. you can select 1.0, 2.0 up to 5.1ch audio if you have a 6 ch. source.
  3. Always Watching guns1inger's Avatar
    In the past (up to and including 7, can't speak for 8), mpeg-2 and AC3 output were not standard. You got them if you installed DVD Architect, or if you licensed them separately.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. vegas pro 8 comes with architect but i don't think you need to install it for ac3 rendering. i could be wrong as i have dvda 5.0 installed also so i can't tell for sure.
  5. AGAINST IDLE SIT nwo's Avatar
    found out from the sony help center that i had to reinstall vegas as the download from there site was missing files, and they had just put out a new build, so it all working now.
  1. Replies: 8
    Last Post: 27th Aug 2011, 18:41
  2. Vegas Pro 9e - Can't render AC3
    By stantheman1976 in forum Audio
    Last Post: 24th Nov 2010, 17:59
  3. Sony Vegas Render Problem
    By xfam0usx in forum Editing
    Last Post: 14th Aug 2010, 20:04
  4. Opening .ac3 audio files in Sony Vegas?
    By Thunderhead2772 in forum Editing
    Last Post: 18th Jul 2010, 20:55
  5. Vegas smart render using mpeg2 ac3 files
    By Ferdinand in forum Editing
    Last Post: 9th Nov 2008, 10:00
