Hello,
I have some wmvhd files with wma pro 5.1, that I extracted and converted to 5.1 ac3. I now need to know how to mux the ac3 into the wmvhd file. any ideas? My goal is to get the wmvhd to play on the ps3 with 5.1 audio,since ps3 doesn't decode 5.1 wma pro audio.
Thread: mux 5.1 ac3 into wmvhd?
AC3 is not supported by .asf or .wmv container
Are you sure of that?AC3 is not supported by the .asf [s:8f29102f57]or .wmv[/s:8f29102f57] container
[ E D I T ]
@ nick101181: have you already tried Solveig's Asf Muxer?
I have never tried to place ac3 audio into an asf container,
but I am pretty sure one can wrap mp3 audio in an asf file without a problem ---
--- I did that a couple of months ago, just for learning purposes.
BUT the real problem is, the PS3 appears to support only "standard" WMA
for the ASF container (at least, that's what the "official speech" says).
Yes, Midzuki you are correct
I did a quick search and found that Solveig ASF Muxer. I was able to put a WMV3 video stream and 6-channel AC3 audio into an .asf container. I never thought this would be possible. It even played back no problems on the PC...However don't know if it will work on PS3 (don't have it here, it's at my brother's house)
Thread:
http://forum.doom9.org/showthread.ph...hlight=wmv+ac3
Download:
http://www.solveigmm.com/files/SMMASF_2006_03_02.zip
thanks for the help but I'm trying to figure out how to use asfmuxer. For input I only see one field, how can I insert both ac3 and the wmv video?
Sorry I forgot to say that I had a wmv in .avi container (wmv video stream, ac3 audio stream). I did this through vdub, which then you could input the .avi into the solveig tool. You can also do this through avidemux, and selecting audio from other file (in this case the AC3)
Here is a sample of the Dark Knight Apple movie trailer (3MB), redone with VC1 and 5.1 AC3 in a .asf container. It indexes fine with asfbin, and both Gspot and Mediainfo report it's really a VC1/5.1 AC3/.asf
Please report back to if it does play correctly on PS3 with 5.1 audio. Maybe try renaming from .asf to .wmv
wvc1%20+%205.1ac3.asf
mux m2ts to m2ts with AC3 audio without reencoding the video
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 21:19 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
How to mux a AC3 file back into a mp4
By Scarpad in forum AudioReplies: 1Last Post: 26th Nov 2009, 10:44 -
shrinking mkvs and wmvhd 2 bluray...a little help please
By tomrip in forum Video ConversionReplies: 10Last Post: 30th Dec 2008, 19:59 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
